Supporting mods for gt28rs?
Old Oct 9, 2007 | 10:18 PM
awoodman's Avatar
Default Supporting mods for gt28rs?
If I go with the gt28rs, what are the supporting mods that I will need to get, in addition to the turbo? I'd like the extra power, but dont want to spend that much more that the K04.
Old Oct 9, 2007 | 10:24 PM
kolan67's Avatar
Default RE: Supporting mods for gt28rs?
ORIGINAL: cincyTT
ATP manifold and dp = $900
t3 60trim = $700
injectors = $300
sw/chip = $800
oil lines (no coolent lines) $100 or less
little more for odds and ends.
searchy
chaos92287's Avatar
you could go with a gtrs elim and just have to get new tuning, injectors, and probly a fmic. but if you went with a gt28rs you would need this kit- http://www.atpturbo.com/Merchant2/me...ory_Code=VVWTK plus injectors and software. you will most likely get bored with a k04 (i am). i would suggest saving up a bit more and getting the gt28rs kit.
Old Oct 10, 2007 | 07:31 AM
ironman's Avatar
K04 is nice if you dont want huge power or still want to drive in the snow in boost. other then that GT series all the way
Old Oct 10, 2007 | 09:24 AM
Papachristou's Avatar
supporting mods besides the obvious (turbo,software,lines, gaskets testpipe/HFC)
what year is your car?
large FMIC (racetec would suffice) er sport would work but ER comp would be the best... but also the most $.. there are several other options.....
clutch spec 3 or southbend OFE ss or FE SS
people have had problems with the spec and OFE lately
BBK
you really shouldnt just throw on a BT without the proper mods to handle the power... its soooooooooo much more power (about double) , u will need the added braking, cornering, clutch, and FMIC to be safe on the road and deliver the power correctly to the road
even with just a 1+ flash i wish i had a BBK sometimes (but the CD/slotted rotors, pads, motul fluid and stainless lines help)
and couldnt see going without the STaSIS streetsports...... best $800 i spent on the car so far
Old Oct 10, 2007 | 10:32 AM
kraylon's Avatar
exaclty if you want to go fast you will need to stop just as fast and what good does 300 whp do if you can't put it on the ground??
bbueschel
Nov 17, 2008 05:41 PM
kevo1.8T
Apr 21, 2008 10:21 PM
sakuraba
Feb 29, 2008 11:08 AM
new2me
9
Mar 5, 2007 05:54 AM
