sway bar install
Old Aug 29, 2006 | 08:53 PM
laxhuskie9's Avatar
Default sway bar install
anyone else have problems with takin the bolts off that are connected to the sway bar links?? (the ones that are attatched to the bushings) I'm havin a hell of a time, the nut is rusted pretty bad to the bolt and the bolt's just spinning inside the bushing. Anyone know what I can do to fix? (any good rust disolvers besides wd40?) thanks for any input...
Old Aug 29, 2006 | 08:56 PM
CO AVANT's Avatar
Default RE: sway bar install
PB Lube
Old Aug 29, 2006 | 09:11 PM
Jeff's Avatar
Zombie Defense Force
you have to put an alan wrench in the middle to keep it from spining if we are thinking about the same bolt
Old Aug 29, 2006 | 09:17 PM
laxhuskie9's Avatar
right you are my man....its amazing some of the **** you don't see that's sooo easy!! thanks
Old Aug 29, 2006 | 11:07 PM
captcaos2002's Avatar
I couldn't get the bolt loose from my control arm I replaced the other day I had to buy a new sway bar link.
redmond1501
Nov 22, 2012 06:52 AM
beachchair
May 18, 2008 09:19 PM
Shazam!
Nov 5, 2006 04:38 PM
TheJazz7
Aug 28, 2006 04:09 AM
