System Disable?
Old Feb 8, 2007 | 01:26 PM
Ford2Audi6's Avatar
Default System Disable?
Doing the timing belt this weekend, and I want to know if disconnecting the battery will disable the airbag system. Is there still a secondary backup for the system when there is no battery. If there is how do you disable it so when I remove the front bumper the airbags dont go off. I know most cars if you disable the battery the system is dead but only had the car for 6 months. If you do dissable the battery where can I find the radio code? In the owners manual? Thanks guys.
Old Feb 8, 2007 | 01:30 PM
new2me's Avatar
Default RE: System Disable?
I did'nt remove the batt. when i did mine with no problems.
Old Feb 8, 2007 | 01:36 PM
cstarky15's Avatar
well the radio code should be in the manual not in the big one but in a little skinny one on the first page. if it is correct. i had to go to audi and pay 40 bucks to get the right code cuz the one i had was wrong.
Old Feb 8, 2007 | 08:32 PM
Ford2Audi6's Avatar
anyone else??, I want to makes sure that removing the battery disables the system!!!! But thanks to you other guys
Old Feb 8, 2007 | 08:41 PM
Jeff's Avatar
Zombie Defense Force
i took off my bumper with out touching the battery and my air bags didnt go off
Old Feb 8, 2007 | 09:27 PM
tractioncontrol's Avatar
Yes if you disconnect the negative terminal on the battery after ten minutes all energy is discharge from the system. It only takes .1 of a volt to activate an airbag. They say to allow ten minutes to make sure no power is stored anywhere but I don't see how it would be "stored" but that is what is recommended.
Old Feb 9, 2007 | 10:00 AM
david9999's Avatar
You don't need to disconnect the battery to do the timing belt. There is no sensor in the bumper that sets off airbags.
yvfed1
Apr 6, 2008 04:05 PM
jged99
Sep 25, 2007 08:32 PM
carhopper
May 9, 2007 07:18 PM
04a4
Jan 28, 2007 12:10 AM
04a4
Jan 26, 2007 04:55 PM
