TBA
Old Apr 19, 2006 | 01:08 PM
smokeU's Avatar
Default TBA
is reseting the ECU and a TBA necessary after installing the ECS n75 race valve?
Old Apr 19, 2006 | 01:40 PM
north5995's Avatar
Default RE: TBA
Not necessary but probably helps. I have done a TBA 3-4 times since installing it just in case.
Old Apr 20, 2006 | 11:56 AM
smokeU's Avatar
Default RE: TBA
if someone could please tell me what the TBA does exactly in detail. I hear clicky noises coming from ecu and behind glove compartment?
just interested in knowing what exactly is going on in there.
knowledge is power
I appreciate any response...
Old Apr 20, 2006 | 12:01 PM
quattrosedan's Avatar
Default RE: TBA
There is a sensor inside of your throttlebody that senses where it should be, like a tps. I believe the TBA just allows it to realign itself.......[&:]......maybe....I could be way off.
Old Apr 20, 2006 | 12:09 PM
north5995's Avatar
Default RE: TBA
Do a search for "TBA" or "Throttle Body Alignment". Its been posted about numerous times.
Old Apr 20, 2006 | 12:28 PM
techbod's Avatar
Default RE: TBA
ORIGINAL: quattrosedan
you are quite right there what it does is tell the computer where the "WOT" ( wide open throttle is ) all you need to do is deck the accelerator peddle to the floor and switch the ignition on "not starting the engine of course" this corrects the reading in the ECM
Old Apr 20, 2006 | 01:32 PM
smokeU's Avatar
Default RE: TBA
really? so in order to do a TBA correctly you floor the gas then turn the key half way and let it adjust for 3 minutes? I've been doing the same thing without the gas pedal floored! what effect does that have and will it make any difference if I do it the other way? I've seen instructions and have searched about TBA but no one ever mentioned flooring the gas then turning the key, just turning the key halfway and listening to the clicking noises while it adjusts...
thanks 4 the responses guys!
Old Apr 20, 2006 | 02:08 PM
techbod's Avatar
Default RE: TBA
basically your telling the computer where the end of acceleration is "ensuring all the cables are set right", WOT ( wide open throttle ) is never achieved on a drive cycle because you cant drive long enough like that without damage so you need to tell the computer the basics then it will set its self up to your driving habits
Old Apr 20, 2006 | 04:02 PM
smokeU's Avatar
Default RE: TBA
ok so I was doing the TBA wrong without flooring the gas? should I reset the ECU then do this or just do it next time I drive my car? thanks a lot.
Old Apr 20, 2006 | 04:06 PM
techbod's Avatar
Default RE: TBA
do it now
