TBA
if someone could please tell me what the TBA does exactly in detail. I hear clicky noises coming from ecu and behind glove compartment?
just interested in knowing what exactly is going on in there.
knowledge is power
I appreciate any response...
knowledge is power
ORIGINAL: quattrosedan
There is a sensor inside of your throttlebody that senses where it should be, like a tps. I believe the TBA just allows it to realign itself.......[&:]......maybe....I could be way off.
really? so in order to do a TBA correctly you floor the gas then turn the key half way and let it adjust for 3 minutes? I've been doing the same thing without the gas pedal floored! what effect does that have and will it make any difference if I do it the other way? I've seen instructions and have searched about TBA but no one ever mentioned flooring the gas then turning the key, just turning the key halfway and listening to the clicking noises while it adjusts...
thanks 4 the responses guys!
basically your telling the computer where the end of acceleration is "ensuring all the cables are set right", WOT ( wide open throttle ) is never achieved on a drive cycle because you cant drive long enough like that without damage so you need to tell the computer the basics then it will set its self up to your driving habits
