Temperature Sensor Issue??
Old Nov 20, 2006 | 03:31 PM
mleahey28's Avatar
Default Temperature Sensor Issue??
Does any one have any info on the location of the sensors for the fuel injection system or have an opinion on this? I'm not that familiar with it and I think I might have a sensor problem. I've done some searching around and can't seem to find any precedent. Cold starts, the engine gets up to idle but then shuts off. I'm thinking it's running too lean on cold startups when it should be running a little richer for the startup. Maybe one of the sensors are giving a false temperature reading? I could be totally lost, it won't be the first time. Any thoughts?
Old Nov 20, 2006 | 03:33 PM
david9999's Avatar
Default RE: Temperature Sensor Issue??
Go to autozone and have them pull the codes for you and post them here.
Old Nov 20, 2006 | 03:48 PM
techbod's Avatar
coolant temp sensor sounds like a good place to start check its resistance while its cold and when its up to temp ( the hotter the temp the lower the resistance )
[IMG]local://upfiles/12092/384C4AF2150342B58DAD5AF7FDBC1D6C.jpg[/IMG]
[IMG]local://upfiles/12092/BD915219FAC14D138C0EECB810BCD064.jpg[/IMG]
n2w
Feb 25, 2013 04:29 AM
jktt
May 16, 2011 08:45 PM
CPR8
Apr 12, 2011 07:58 AM
jameswmcl
Jan 16, 2008 08:41 AM
Tygiganto
Aug 10, 2007 10:34 PM
