Outside temperature issue
Old Feb 12, 2013 | 04:13 AM
n2w's Avatar
n2w
Default Outside temperature issue
Hi All
I have an issue where i lose the outside temp display on the panel in the dash and the relays start going mad under the dash, the climate control still works to create heat etc.
If i remove the instrument cluster and shack the wires or pull of the lower ash panel it starts to work again and maybe fine for months then it goes again, the cluster was repaired about 4 months ago and the company had it back initially when this current fault started happening but nothing as found wrong with it.
Any ideas what may be the cause, outside temp sensor cable or something else
Cheers for your help
Old Feb 12, 2013 | 04:16 AM
n2w's Avatar
n2w
Default update
sorry forgot to say its an A4 B5 1999 Avant SE
Old Feb 25, 2013 | 04:20 AM
Eldildurnon's Avatar
Default garcinia-cambogia
garcinia cambogia extract
Old Feb 25, 2013 | 04:23 AM
Default Electronics
Everyone use electronics product..And all are related to different diffrent products.
Old Feb 25, 2013 | 04:29 AM
Default Electronics
Josiah31
May 29, 2016 03:20 PM
Deusilan
B7 Models
Oct 24, 2012 07:04 PM
jktt
May 16, 2011 08:45 PM
Tygiganto
Aug 10, 2007 10:34 PM
mleahey28
Nov 20, 2006 03:48 PM
