test pipe
Old Nov 17, 2005 | 02:39 AM
droo587's Avatar
Default test pipe
well today my ecode test pipe came. Install is a BIATCH. since my cat broke off from the turbo i decided to upgrade. Any how to keep a long story short i finally got the cat off my cutting the bolts with a torch. Now getting it on i have a problem i stil cant figure out. How to tighten down the bolts connecting to the downpipe. i cant seem to tighten down the bolt thats right at the curve area (bottom bolt). Right now i got 2 bolts tight and the 3rd one is on but not tight. I NEED HELP!! so far the car sounds sick, i'll post up some pic n vids too, hp gains can be felt, now i can actually glue me to the seat a lil haha. and with the cat back borla it sounds crazy.
Old Nov 17, 2005 | 03:06 AM
trailboss's Avatar
Default RE: test pipe
did you try above the driveaxle in the wheel well. Im sure you did, but if not give that a try.
Old Nov 17, 2005 | 04:09 AM
BaconBait's Avatar
I'm glad I saved a pic of that damn thing. This is the way I got it on and off. Look very closely at how the universal joint is positioned. It took a good amount of time turning that thing 1/8 of a turn at a time, but it'll get the job done.
large pic of the pita
Old Nov 17, 2005 | 04:40 AM
droo587's Avatar
that bolt i actually had no trouble. its the ones down the other side thats being a pita. Any ideas?
Old Nov 17, 2005 | 05:56 AM
Session101's Avatar
post some pix and sound clips
Old Nov 17, 2005 | 10:19 AM
droo587's Avatar
yeh after most definitely after i tighten down that last bolt and do the 02 sensor mod.
Old Nov 17, 2005 | 11:38 AM
audiboy1618's Avatar
I used to the think the testpipe install was hard aswell. After a stage 3 install, there a breeze.
Old Nov 18, 2005 | 01:38 AM
droo587's Avatar
How you tighten down that bolt thats right ontop of the cv boot shield?
Old Nov 18, 2005 | 01:42 AM
First make sure everything is outa the way,even 02s sensors if u need to.. Take a 3/8 drive and throw on 2 extensions,a 3/8 swivel, and 13mm socket. Have a buddy hold the back of the nut if it spins with a open box end wrench from the bottom of the car. If you u dont have anyone to help yuu, vice grip it.
Old Nov 18, 2005 | 01:48 AM
droo587's Avatar
sweet, ima do that 2morrow
