Throttle Body problems
Old Nov 15, 2004 | 08:08 PM
  #21
David_K's Avatar
Default RE: Throttle Body problems
Thats what they said in preskool!!
Naw im just Fuc$in with ya. your fun to screw around with. will do no more
Old Nov 18, 2004 | 05:21 PM
  #22
gregp1962's Avatar
OK, I fixed it without replacing anything!! On the advice of someone on another forum, I disconnected the ECU, took off the TB cleaned it up AND opened up the TPS. I blew out the inside of the TPS with air. Put it all back together. It's been a little more than a day now. NO CODES!!
From now on, when I get a recommendation to replace something that isn't clearly broken, I'm going to remove it, clean it, inspect it. If all looks good, put it back and see if it works. Disconnecting the ECU while doing to work might help. Someone told me that ca reset the CEL better than disconnecting the battery. Not sure if it's true. Seemed to work in this case.
I was told that I needed a new TB. I could have spent 350.00. (650.00 at the dealer) For NOTHING. Come to the forum BEFORE you do any repairs that you are not 100% sure about.
Old Nov 18, 2004 | 05:24 PM
  #23
Jestnomen's Avatar
6th Gear
well of course! Glad everything worked out for the best!
soulstep
Jan 13, 2014 08:09 PM
crazyquik22023
Sep 9, 2011 08:06 PM
kraylon
Sep 2, 2009 09:32 PM
allroadguy
Nov 4, 2007 07:52 PM
