Tie rod issues
Old Dec 3, 2006 | 05:24 PM
immgeorge's Avatar
Default Tie rod issues
Ok, so here is my dilemna. I had some vibrations after brand new tires, so I checked out my wheel well and found my outer tie rod ends were completely shot. I just finishing replacing my 1st one, and I got the wheel tightened back on, but I noticed side to side play in the suspension. So... From my understanding of the tie rods, there are just 2 parts, the inner tie rod & boot and the outer tie rod, right? Since I just replaced the outer tie rod end, this must be a problem with the inner tie rod end, correct?
Old Dec 3, 2006 | 05:49 PM
techbod's Avatar
Default RE: Tie rod issues
im thinking track control arm item number 25, first picture is the track rod end /tie rod as you call it
[IMG]local://upfiles/12092/C91116A41528478CB52F135618E7423A.jpg[/IMG]
[IMG]local://upfiles/12092/69CAA11F47C74F3F83278B3495B642F3.jpg[/IMG]
Old Dec 3, 2006 | 05:52 PM
techbod's Avatar
Front axle component layout
Layout of components
Hexagon bolt, 75 Nm
Washer
Hexagon bolt
â—† Note different bolt lengths
‒ With steel mounting bracket: M10 x 60
‒ With aluminium mounting bracket:
M10 x 62
â—† Always replace after removing
Rear upper link
â—† Heed different versions: With and without buffer stop =>Fig.1 and Fig.2
â—† Replacing bush => Page 40-137
Hexagon bolt, 5 Nm
â—† Screw on until contact is made
Bolt
Self-locking nut, 50 Nm
â—† 42 Nm for steel wheel bearing housing
â—† 50 Nm for aluminium wheel bearing housing
Hexagon bolt M 10 x 100
â—† If hexagon bolt cannot be removed from wheel bearing housing -Item 40-113
Self-locking nut, 40 Nm
Front upper link
â—† Can only be removed together with mounting bracket
â—† Removing and installing mounting bracket => Page 40-125
â—† Replacing bush => Page 40-125
Suspension strut
â—† Note different spring/shock absorber versions => Page 40-77, vehicle data sticker
â—† Removing and installing=>Page 40-67
â—† Servicing => Page 40-74
Hexagon bolt
M 12 x 1.5 x 120
Lower guide link
If leaking, hydro-bush must be replaced => Page 40-167
â—† Assignment
=> Parts List
Self-locking nut
â—† Assignment
=> Parts List
â—† Flange nut, M12 x 1.5, for wheel bearing housing with no bushing (old version)
Tightening torque: 100 Nm
â—† Combi nut, M12 x 1.5, for wheel bearing housing with bushing (new version)
Tightening torque: 125 Nm
â—† Vehicles with wheel bearing housings with no bushings and old type track control links -Item 25- are to be fitted with flange nuts
â—† On installing wheel bearing housings with bushings, flange nuts are to be replaced with combi nuts
Wheel bearing housing/wheel bearing housing with bolted wheel bearing
â—† Assignment
=> Parts List
â—† Different wheel bearing housing versions (with and without bushings) => Page 40-85
=> Page 40-85
â—† Servicing wheel bearing housing
=> Page 40-95
â—† Servicing wheel bearing housing with bolted bearing => Page 40-113
â—† For vehicles with headlight range control, heed notes on removal and installation => Page 40-22
Splash plate
Hexagon bolt
Vehicle must be standing on ground when tightening bolt
Tightening torques:
M14 bolt:
◆ 115 Nm + further 180° turn
M16 bolt:
◆ 190 Nm + further 180° turn
Hexagon socket-head bolt, 10 Nm
Self-locking nut
â—† Assignment
=> Parts List
Hexagon bolt M 12 x 1.5 x 85
Note:
On vehicles as of the following chassis numbers, the suspension strut bolted joint was re-positioned, i.e. bolt head faces in direction of travel and nut -Item 21- is located between track control link and guide link
-Items 25 and 13-:
â—† 8D1A 146 169 (Model Year 2001)
â—† 8D2A 000 512 (Model Year 2002)
â—† 8D1N 905 194 (RS4)
Self-locking nut, 90 Nm
Connecting link
â—† Note modified connecting links and tightening torques => Page 40-19
Arrow on connecting link points in direction of travel
Self-locking hexagon nut
◆ 40 Nm + further 90° turn
â—† Underside of nut is ribbed
Make exclusive use of this special nut as replacement part
Hexagon bolt M 12 x 1.5 x 100
Track control link
â—† Assignment
=> Parts List
â—† Different track control link versions (for wheel bearing housings with and without bushings)=> Page 40-154
â—† Servicing => Page 40-159
â—† For vehicles with headlight range control, heed notes on sender removal and installation => Page 40-22
Clip
â—† Always replace
â—† Inserted in track control link
Hexagon bolt, 75 Nm
â—† M10 x 70
Hexagon bolt M 12 x 1.5 x 110
◆ 110 Nm + further 90° turn
Subframe
=> Page 40-139
â—† Servicing => Page 40-148
Self-locking nut, 100 Nm
Hexagon bolt
â—† M8 x 25
â—† Tightening torques:
‒ Non-ribbed bolt: 30 Nm => Fig.3
‒ Ribbed bolt: 75 Nm => Fig.3
Subframe support
Self-locking nut
◆ 80 Nm + further 90° turn
Self-locking nut
◆ 90 Nm + further 90° turn
Multi-point socket head bolt
Tightening torques:
Bolt M8 x 48: 40 Nm
Bolt M10 x 48: 80 Nm
Packing plate
Drive shaft
â—† Removing and installing=>Page 40-27
â—† Servicing => Page 40-30
Drive shaft with triple roller joint
â—† Servicing => Page 40-47
Twelve-point hexagon socket-head bolt, 80 Nm
â—† For vehicles with triple roller joint
â—† M10 x 20
Hexagon bolt
M10 x 62
Mounting bracket
=> Page 40-125
â—† Aluminium mounting brackets were introduced as of MY 98
â—† Heed correspondingly amended wheel alignment specifications
=>Pages 44-23
â—† Combination of different types (aluminium/steel mounting brackets) is not permitted
Self-locking nut
◆ 50 Nm + further 90° turn
Self-locking flange nut, 20 Nm
Stop plates were introduced as end stops as of chassis number -8DTA 321 912- for vehicles with sports and heavy-duty running gear.
Note:
Stop plates are not to be removed.
→ Fig.1 Stop plates
A - Cap
B - Stop plate
C - Rear upper link
D - Body
Buffer stop was introduced as of Model Year '97 at rear upper links.
→ Fig.2 Buffer stop
A - Rear upper link with buffer stop
Note:
On replacing rear upper link, make sure vehicles with no stop plates are always fitted with new link.
Attention:
Vehicles with stop plates are still fitted with link with no buffer stop.
Stop plate is not to be removed.
→ Fig.3 Heed different tightening torques
Exclusive use has been made of ribbed bolts since Model Year '98. These bolts may also be used on older models.
‒ Non-ribbed bolt -A- (arrow)
Tightening torque: 30 Nm
‒ Ribbed bolt -B- (arrow)
Tightening torque: 75 Nm
Old Dec 3, 2006 | 05:54 PM
techbod's Avatar
I was hoping all the pictures would have been pasted there but no such luck but still some good information there
Old Dec 3, 2006 | 05:59 PM
techbod's Avatar
rest of diagrams so you can put it together
[IMG]local://upfiles/12092/2292EE065E314A44B0049D3355A0C759.jpg[/IMG]
[IMG]local://upfiles/12092/1CA052B85FE14278A98AA77DF5574D4B.jpg[/IMG]
[IMG]local://upfiles/12092/06123D299A0343C888439691A7A9079D.jpg[/IMG]
Old Dec 3, 2006 | 06:05 PM
immgeorge's Avatar
I went and checked everything out. All the joints actually seem to be fine. I actually took the outer tie rod end off again trying to isolate the movement. I was able to move the inner tie rod about 2-3 mm in and out... So I'm positive that's my problem. I've been searching for inner tie rod replacement but can't seem to find any walkthroughs or anything pictures on it.
Old Dec 3, 2006 | 06:27 PM
techbod's Avatar
Steering box (left-hand drive)
Exploded view
Hexagon bolt, 68 Nm
Boot
â—† Check for cracks and abrasion
Eccentric bolt
â—† Torx T50
â—† Turn clockwise to slacken off
â—† Turn anti-clockwise to tension
Steering column
Self-locking hexagon nut, 30 Nm
â—† Always replace
Combi bolt, 7 Nm
â—† For adjusting toe-in curve
Bolt
Self-locking nut
â—† Always replace
Return hose
Expansion hose
Cheese-head bolt, 13 Nm
â—† Screw plug of steering centring
=> Fig.1
Power-assisted steering box with track rods
Banjo bolt, 40 Nm
â—† With integrated non-return valve
Sealing ring, 14 *20
â—† Always replace
Banjo bolt, 50 Nm
Sealing ring, 16 *22
â—† Always replace
Hexagon bolt, 35 Nm
Steering damper
â—† Only for:
‒ 6-cyl. models
‒ As of MY` 98 all 4-cyl. models as of 132 kW
Bushing
Rubber bush
â—† Two-piece
Hexagon nut, 10 Nm
â—† Provide support at hexagon of steering damper piston rod when slackening off and tightening
→ Fig.1 Screw plug of steering centring
1 - Screw plug of steering centring, 13 Nm
2 - Tapped hole in steering box
[IMG]local://upfiles/12092/299DF7459C81422F9ABD02BF08885BD5.jpg[/IMG]
[IMG]local://upfiles/12092/61D6676125654956A34EBBEAC5C88435.jpg[/IMG]
Old Dec 3, 2006 | 07:09 PM
immgeorge's Avatar
Ok, so I've confirmed the play is coming from a ball joint that connects to what I'm guessing is the rack. I can't get back in there really well, but I'm going to take some pictures to show what I'm talking about. I can't really tell how it comes off from the technical diagrams.
Old Dec 3, 2006 | 08:22 PM
immgeorge's Avatar
ok, so here is the picture of the ball joint that has gone bad. I don't know how to get it off... any help?
[IMG]local://upfiles/18314/67C64C75F234419DB951EECB462DC166.jpg[/IMG]
Old Dec 3, 2006 | 08:46 PM
techbod's Avatar
not sure you can buy that part on its own but there is a cheat otherwise its a complete steering rack
note I have pointed the areas that need hammering in to re-compress the ball joint to eliminate movement ( not the best way but a quick fix )
[IMG]local://upfiles/12092/92F87E2CD3284DCA8340FDE3106885AC.jpg[/IMG]
