Tie rod issues
Old Dec 3, 2006 | 08:54 PM
techbod's Avatar
Default RE: Tie rod issues
the ball joint your looking at ive marked on these drawings
[IMG]local://upfiles/12092/BDE328BCA8124A2CB67B0057AA3862C8.jpg[/IMG]
[IMG]local://upfiles/12092/BF22DF95C0934E5987900E96DCD4A0AB.jpg[/IMG]
Old Dec 3, 2006 | 09:14 PM
techbod's Avatar
actually my mate says you can buy the plastic washer that goes in where the ball joint is and that bit unscrews to fit it, never done one like that I normally change the whole thing so new one to me but im sure he is right so ill try to get some information on that
[IMG]local://upfiles/12092/A9A64BF03A3E4D6F91F1564D7FDA3D62.jpg[/IMG]
Old Dec 3, 2006 | 10:22 PM
immgeorge's Avatar
Alright, I'm guessing that that housing just unscrews like normal? Anything I should watch out for or be careful of when using force to break it loose? I can't mess up the rack or anything else with steering can I? Here is a link to some inner tie rods, there are lots of other sites that have them. I'm just hoping the shop that I got the outers from carry the inners as well.
Also, I've only been working on my drivers side. What are the odds the other inner is bad too??? [:@]
Old Dec 4, 2006 | 05:17 AM
acetrebo's Avatar
Yeah, just replace that inner.
I wouldn't expect the other side to be bad also, but hard to say. just tear it apart and take a look.
Old Dec 4, 2006 | 07:27 PM
immgeorge's Avatar
should i be able to break this bugger loose with big channel locks? they told me a needed a tool but logic says channel locks would work
Old Dec 4, 2006 | 07:41 PM
techbod's Avatar
monkey wrench if you can get in there with is
[IMG]local://upfiles/12092/AE42D6CC9D3E4A84AB0CF6B2D2035C41.jpg[/IMG]
Old Dec 5, 2006 | 07:56 PM
immgeorge's Avatar
I'm having a hell of a time trying to break this thing loose. Any ideas on how to break that housing free from the steering rack?
Old Dec 5, 2006 | 08:18 PM
  #18
techbod's Avatar
check the rear of the ball joint holder and see if it looks like its threaded later ones could be a single unit and a recon unit might be the only way to resolve it
Old Dec 5, 2006 | 08:20 PM
  #19
rbrtech's Avatar
If you notice there is a notch just behind the big nut where the joint is. Hold that with a 22mm (I think thats the size) also make sure you have the wheel turned so that its at its full extension. Then use the good old monkey wrench or 1 1/4 wrench
Old Dec 5, 2006 | 08:37 PM
  #20
immgeorge's Avatar
ah thanks, maybe thats the ticket... off to get a huge wrench
