is it time for a new battery?
Old Jan 23, 2006 | 03:34 PM
98 A4 Turbo's Avatar
Default is it time for a new battery?
my battery meter reads a consistant 14 volts. does this mean that its time for a new battery since 12 volts would be normal i think... thanks!
Old Jan 23, 2006 | 04:06 PM
Jeff's Avatar
Zombie Defense Force
Default RE: is it time for a new battery?
mine is at 14 all the time and it works fine. only get a new one if its not starting ur car
Old Jan 23, 2006 | 04:10 PM
Fieldy's Avatar
if you have a AAA membership, you can just call them and have a battery truck show up and test yours.
the'll give ya a print out with it's "health."
Old Jan 23, 2006 | 04:44 PM
brrman's Avatar
your battery meter? Are you talking about your voltage read out in the dash? That should run 14v while the car is running since thats what the alternator puts out.
Typical dead battery symptoms are a repeated clicking when you turn the key, or obviously a slow engine turn over.
Old Jan 23, 2006 | 10:09 PM
o aright... i thought it should read 12 since the battery is a 12V. The car turns fine though so im all good. thanks for the advice!
Old Jan 23, 2006 | 10:13 PM
Kellya4's Avatar
A voltmeter will read at 13.8 volts with the car running. A battery fully charged will read 12.50 - 12.6 something if you check the battery by itself.
x_noodle_x
B7 Models
Dec 27, 2012 09:07 PM
Skidog
Dec 15, 2010 06:08 PM
