Time for a question
2000 1.8tQ, APR chip, with 102K miles on it.
I purchased it used with about 75K miles . Oil was changed fairly regularly, likely with Dino from dealer.
Since I purchased it 8 months ago, I've changed every 5K miles with synthetic 5W-40 and Mann filters.
Engine makes some lifter noise. Looking through the filler, I don't see evidence of gross sludge, just the usual varnish.
What are the thoughts regarding doing an engine flush? Jiffy lube wallet flush...errrr, engine flush for about 75 dollars, a can of gunk engine flush, nothing?
Thanks
Thanks
Check your oil for smoothness. Remove dipstick , and rub oil between fingers. Remove oil refill cover. Remove some oil with a finger from the valve cover. If it's smooth your OK.
One thing not to sure how mechanicly inclined u are but you might be getting time for a new oil pump with that K on it you could buy some time buy taking the oil pan off and cutting the screnn out of the oil pick up
skylight
Mar 15, 2007 10:41 PM
