timing belt
Old Mar 7, 2006 | 01:13 AM
mrhurst88's Avatar
Default timing belt
im right at about 70k and i was wondering if it was about that time to get my belt replaced....if not now, when is a good time?
Old Mar 7, 2006 | 01:24 AM
BadLuckAudi's Avatar
Default RE: timing belt
Yep deff a good time to do it, you dont want to push something like a t belt if it goes it will most likely take the rest of the motor with it so its better to be safe than sorry
Old Mar 7, 2006 | 01:26 AM
mrhurst88's Avatar
yeah the cost of repair will be crazy...i want to do it soon!
Old Mar 7, 2006 | 01:45 AM
Blitzfitz2150's Avatar
whats the cost for getting the belt changed? roughly... i know the belt itself isn't expensive but the labor to put it on is ganna run me? my odo is at 95k so i have to call the last owner and see if it was changed and if not i guess i def need to do that
Old Mar 7, 2006 | 02:20 AM
Simone's Avatar
anywhere from $700 to $1000 to get it replaced, depending on where you go...
(timing belt)
Old Mar 7, 2006 | 05:39 AM
Jeff's Avatar
Zombie Defense Force
do it now, u will see some guys just broke at 62xxx so imo now
Old Mar 7, 2006 | 09:07 AM
david9999's Avatar
3-500 for labor You also need to change all the associated parts including tensionwer, idler. Should do front engine seals and water pump at same time.
Audiguruforyou
Sep 20, 2011 01:31 AM
vtraudt
Apr 1, 2011 09:40 AM
TheBat
Jun 20, 2008 01:14 PM
