timing belt kit
The timing belt should be changed around 70-80k. If your timing belt snaps the preset camshaft valve lifts will be off and the pistons will smash into the valves destroying the engine head or the pistons themselves. In other words your engine will be fvcked, and its $5000+ repair. Its not reallly the timing belt that goes bad its the rollers that seize therefore snapping the belt. The kit usually comes with a water pump. Its optional but might as well change the water pump while the front end is off.
Audiguruforyou
Sep 20, 2011 01:31 AM
Jeffla
Jan 3, 2010 04:43 AM
fritz
Aug 12, 2007 02:55 PM
