timing belt question
Old Jul 5, 2005 | 03:21 PM
dericm610's Avatar
Default timing belt question
Hi guys, I am new to the forum. Just wondering if anyone knows if there is any difference in using a dayco timing belt or a conitech timing belt? Does it matter which one I use? Also, has anyone bought the timing kits from ECStuning.com? I just bought a 2000 A4 1.8TQ with 61K. Just wondering which one I should get, the regular kit or the ultimate. Any recommendations will be greatly appreciated. Thanks!
Old Jul 5, 2005 | 03:42 PM
david9999's Avatar
Default RE: timing belt question
Hi, welcome to the forum.
As part of the welcome, I would like to introduce you to the search function which can answer many basic questions.
The Dayco belt is fine.
almost everyone buys the ECS kit. I bought the ultimate kit.
Might as well change everything, as the major cost is labor to access the area.
Old Jul 5, 2005 | 04:03 PM
skidplatexa4's Avatar
Get the ultimate timing belt kit. They give you everything you need to complete the job at a nice price. I did mine last month the kit worked great and in n6 hours my car was back together and ready to go. If you are planning on modding your car too while your in there replace the snub mount since it is right there.
Old Jul 5, 2005 | 04:48 PM
dericm610's Avatar
Thanks for the recommendation guys. Will probably get the ultimate kit as well.
Old Jul 5, 2005 | 05:17 PM
insuite's Avatar
get a new o-ring for where the water pump housing meets the engine block. it's the only thing missing from the ultimate kit from ecs.
Old Jul 5, 2005 | 06:45 PM
ORIGINAL: insuite
when i got the kit the o ring was there.
Old Jul 5, 2005 | 06:51 PM
dericm610's Avatar
What's the difference between the new O ring and the old one?
Old Jul 5, 2005 | 07:21 PM
DarkHelmet's Avatar
age?
(but thx for this post... I am researching all related posts to see what I needed IN ADDITION to the ECS ultimate kit... so far the diverter and (maybe) seals for the cams (I think)...
Old Jul 5, 2005 | 09:12 PM
david9999's Avatar
Front engine seals (3) are a good idea. Again, you are there and replacing the part takes 10 minutes and costs about 10 dollars
Old Jul 5, 2005 | 09:21 PM
BFlan2001's Avatar
SNUB MOUNT is very important..it will cut down on driveline shock and give you smoother shifts, and it's only 15 bucks from www.greedspeed.com (or 50 bucks at ecs or anywhere else)
Yagimax
Sep 26, 2012 05:29 PM
sollyd25
Jan 11, 2011 01:01 AM
Jessie2k
Aug 5, 2008 01:39 PM
xX|05:A4|Xx
May 3, 2008 08:28 AM
cdf619
Oct 25, 2005 05:56 AM
