timing belt question
Old Nov 14, 2004 | 10:24 PM
fullboostin's Avatar
Default timing belt question
I noticed on some parts sites that there are 2 different timing belt applications for my 98' a4 1.8t quattro. How do i know which one to use?
Old Nov 14, 2004 | 10:27 PM
Jestnomen's Avatar
6th Gear
Default RE: timing belt question
do you have a link?
Old Nov 15, 2004 | 01:14 AM
Old Nov 15, 2004 | 01:27 AM
Jestnomen's Avatar
6th Gear
Are you talking about the two "300" links? The top one says its for a car without the updated tensioner, the lower is for a car with the tensioner.
Have you looked at ECSTuning.com? I bought all my timing belt goodies from them. They even have an "ultimate timing belt kit" with everything you need (water pump, gaskets, idle pullies, etc).
Old Nov 15, 2004 | 02:16 AM
yes.. thanks ill check that out.
Old Nov 15, 2004 | 02:33 AM
David_K's Avatar
it comes with a water pump? how much was this?
Old Nov 15, 2004 | 02:37 AM
Jestnomen's Avatar
6th Gear
yeah it comes with everything you need sans G12/tools/gasket remover.
I think it was around $250
Old Nov 15, 2004 | 02:44 AM
sounds like a good deal... but i didnt know the water pump and such was also recommended to be replaced.
Im a new audi owner so dont laugh, but where can i find my engine code?
Old Nov 15, 2004 | 02:48 AM
David_K's Avatar
wow sounds eccelent!! i might have to do it again just for fun!!
Old Nov 15, 2004 | 03:54 AM
brrman's Avatar
always replace the water pump impellar if you have a 1,8t... The 1.8's timing belt runs the the water pump, so if the impellar goes bad it will throw/shred the belt and you are in a world of hurt.
Your engine code is stamped on the head, not sure but it may be under the engine cover with the 4 rings, or it may be just below it (towards the front of the car)
