timing belt question
Old Nov 15, 2004 | 07:23 AM
david9999's Avatar
Default RE: timing belt question
The engine code will also be found in the vehicle ID sticker in the spare wheel well.
Old Nov 15, 2004 | 08:20 AM
Jestnomen's Avatar
6th Gear
David, the timing belt change is anything but fun.
This tutorial will show you the procedure.
It took me about 13 hours this summer to complete mine.
Old Nov 15, 2004 | 12:25 PM
clconversion's Avatar
I pretty sure thats only on the 2001's awm engine code the atw's and aeb's have external water pumps
ORIGINAL: brrman
always replace the water pump impellar if you have a 1,8t... The 1.8's timing belt runs the the water pump, so if the impellar goes bad it will throw/shred the belt and you are in a world of hurt.
Your engine code is stamped on the head, not sure but it may be under the engine cover with the 4 rings, or it may be just below it (towards the front of the car)
Old Nov 15, 2004 | 12:50 PM
brrman's Avatar
hmm yes your right now that I check.
Yagimax
Sep 26, 2012 05:29 PM
sollyd25
Jan 11, 2011 01:01 AM
Jessie2k
Aug 5, 2008 01:39 PM
xX|05:A4|Xx
May 3, 2008 08:28 AM
cdf619
Oct 25, 2005 05:56 AM
