Timing belt replacement in progress, please help.
I am in the process of replacing my timing belt and got stuck today on the dampener pulley. Was following the tutorial on audizine.comL:
http://www.audizine.com/forum/showth...er-Pump-Change
NOw I am at step #3:
3. Remove the dampner pulley; have hold the pulley with a 19mm 12pt. socket on a breaker bar, while you remove the four 6mm hex bolts (Allen keys won't cut it here, you'll need a socketed hex).
Does anyone know if I am supposed to remove the big huge 12pt/19mm socket??
Here's a picture of what I've done on my dampener pulley. I've taken off the four 6mm hex bolts, but cannot take off the dampener pulley.
fritz
Aug 12, 2007 02:55 PM
