Timing belt tensioners one time use?
Old Apr 22, 2007 | 09:44 PM
Andyrew's Avatar
Default Timing belt tensioners one time use?
So I have to take the timing belt off to put on the new gasket for the water pump. But I have a new tensioner, all new belts, ect...I just overtightened the water pump gasket and it leaked. Now I have a new (much better) gasket to install.. and I didnt purchase a new tensioner because I assumed I didnt need to.. Now I would like to know if the timing belt tensioners are one time use items.. IE pull the pin, and your done with that one.
I had to use alot of pressure to push the rod back in enough to put the pin in.. But now the tensioner pin can slide in and out without work.
Anyone know?
Thanks
Andrew
Old Apr 22, 2007 | 11:05 PM
akielb's Avatar
Default RE: Timing belt tensioners one time use?
I would think that It would be damn near impossible to re-install the tensioner. it might be possible but since it sounds like you broke the tensioner I would replace it. Since you just did the TB job I would just pick up a new tensioner from ecs or where ever.
Old Apr 23, 2007 | 12:13 AM
Andyrew's Avatar
It takes a week for anything to get here from ECS...
Also the audi is my driver...
The tensioner had tension on the pin after it sat for a couple of minutes so I reinstalled it and everything seems to be fine... We'll see.
Old Apr 23, 2007 | 12:20 AM
akielb's Avatar
ooooooooooo - RISKY - good luck - if the belt does skip it will cost you $3k so gooooood luck. where are you at - would Purems.com be closer - can you call ecs and get it overnighted. don't risk it
Old Apr 23, 2007 | 12:35 AM
willard00's Avatar
i dont know if they are so much one time use...but i was reading up on how to change the timing belt and i read that when the timing belt is changed it is recommended that the tensioner be changed as well. so it might be a good idea.
Old Apr 23, 2007 | 01:05 AM
akielb's Avatar
willard - we don't do the timing belt job to change the timing belt - we do it to change the tensioner because it has a tendencey to fail and allows the belt to jump teeth.
B5LVR
Nov 6, 2010 09:00 PM
moeron7
Jul 10, 2008 12:46 PM
socalaudi
Mar 13, 2006 02:39 AM
2.8AudiA4
Mar 5, 2005 12:48 AM
