Timing Belt Tools!? HELP!
Old Jul 14, 2005 | 05:40 AM
dan908's Avatar
Default RE: Timing Belt Tools!? HELP!
Aw come on guys I just did a 2.8 timing belt replace in under 3 hours. It is pretty easy if you are handy on a car.
My Dad's a ford mechanic so I used the good ole american way and I aint saying it is right but it worked just fine.
Instead of using the tools recommended, you can mark the belt and count teeth (double count) I would not include the camshaft seals as part of the operation, that took me ~22 hours.
But basically, set the engine at top dead center and make sure you are not sitting half way on a turn over (anything spins with no tool and you are screwed). Remove all the plastic and the crank pulley ~8-10 bolts (for serp belt). Now start marking. double mark all your gears on both the belt and gears, preferably either side of the gear, with a stripe that can be matched up (not a fat dot that can be misaligned later). I used white out. Check and be sure you are ready. The tensioner fits an 8 and a 6 hex, it is about center on the engine, the 6 is a bolt the 8 is a slot. Crank the 8 to come loose, the 6 to remove, (the other way and you'll just break something). You should have a replacement tensioner. There is also a second pulley you should replace to he right. Pull that one next and replace. Next, remove and replace the water pump and thermostat (I am assuming you can do this without direction if you cannot find a local mechanic for sure). Now to put on the new timing belt, you can finally take off the timing belt knowing exactly which marks came from where. Mark your new belt exactly like your old belt, counting teeth between marks 2-3 times to be sure. When done going all the way around, hold up the two belts and check again, you cannot be wrong on this. Then put the belt back where the marks line up on the gears. If you cannot line up on marks, you screwed up. But as long as you did not ever turn anything, you will still be in the same spot the whole time. If the teeth spin ever so slightly, do not think you can just turn back by going a loop, it aint true. I would strongly discourage pulling really hard on the belt when reinstalling and if anything is not quite fitting right well that is for you to figure out. Mine went right so I can't give good advice.
Hey you wanted to know how to do it with out the tool, that is how. Quick and Easy. But if you are not really familiar with how it all works, leave it to a pro.
Old Jul 14, 2005 | 10:20 AM
mdyoungb's Avatar
I have done timing belt jobs before....On an Acura and an older BMW. Not too worried about the job itself, just want to do it right the first time. I would prefer to do the job with the tools as a means of insurance.
Old Jul 14, 2005 | 10:49 AM
lidonnit's Avatar
Insurance?
Old Jul 14, 2005 | 11:35 AM
mdyoungb's Avatar
Insurance...i.e., a mode of preventing a screw up. (Or at least helping prevent)
Old Jul 14, 2005 | 02:24 PM
audiboy1618's Avatar
ORIGINAL: dan908
Hahaha, thats one way of doing it.
Old Jul 17, 2005 | 03:04 PM
dan908's Avatar
Hey it saves a whole crap load of money!
Sure there are other techniques, but with out buying tools, this one seemed like the most logical.
Old Jul 17, 2005 | 03:13 PM
terpsfan98's Avatar
I made my own camshaft locking tool. Took a little bit of time though. Once I got everything torn down, I took measurements of the cams and got 2x2 piece of wood, drilled some holes and ran some screws through it and attached them with nuts. Worked perfectly.
Old Jul 18, 2005 | 05:23 AM
  #18
lidonnit's Avatar
I like that idea.... what do you bolt it to exactly? top to bottem end?
Old Jul 18, 2005 | 04:17 PM
  #19
brrman's Avatar
on a 2.8 you really should have the cam locking tool.
Other than that a TB job on an audi is not that difficult. Not nearly as difficult as my GF's 2.5 Subaru Forester.
Old Jul 18, 2005 | 04:27 PM
  #20
Jestnomen's Avatar
6th Gear
Exactly, I would never do the job without the correct tools. When I did mine, it was very easy to mess things up.
