Timing belt. Updated with pics
Old Apr 19, 2007 | 03:28 AM
sdboarder84's Avatar
Default Timing belt. Updated with pics
How hard is it to replace/ check the timinr belt? I just bought an 01 A4 with 85,000 mi on it. Wondering if it would have been replaced already ? The car was well taken care of it has the orignal window sticker and everything. How much should I expect to pay for a timing belt change should I have someone else do it? What parts would I need to do it my self?
here is a picture of my belt. still has a lot of blue and you can see all of the writing. was done a short time ago or is what they look like when you guys get around to replacing them?
Old Apr 19, 2007 | 03:48 AM
cincyTT's Avatar
I'm make believe
Default RE: Timing belt
If you have a 1.8t, this should be a good reference in what is needed (its on a gti so the steps are not 100% the same)
Timing belt DIY
Old Apr 19, 2007 | 03:56 AM
sean1.8t's Avatar
^^how about we get him the correct write up eh?
http://www.audiworld.com/tech/eng35.shtmlhere is what you're looking for. it isn't hard really, it is just time consuming
Old Apr 19, 2007 | 04:07 AM
Thanks for the quik responce guys. it is AWM 1.8T. any more pointers to help out an Audi newbie?
Old Apr 19, 2007 | 04:17 AM
cincyTT's Avatar
I'm make believe
Its what i knew of hand that had a bunch of pics.
Old Apr 19, 2007 | 05:21 AM
Flip's Avatar
I would check the service records first to make sure it hasn't already been done.
Old Apr 19, 2007 | 11:25 AM
david9999's Avatar
It is time. The parts run 275 over the net for belt and related hardware. Depending on the shop, labor runs 400-600 dollars.
If it hasn't been done already (which I doubt), it is time. Audi engines are interference engines which means that if the timing belt slips, the pistons hit the valves and you are looking at a 2500 dollar job for new valves.
Old Apr 19, 2007 | 01:10 PM
How would I go about checking the service records to see if it has been done?
Old Apr 19, 2007 | 01:15 PM
Cruz734's Avatar
Just wondering,How do you know it may need a new timing belt? Is something wrong with the car now?
I have a 2001 A4 1.8T with 56K miles and I think I may need a timing belt as well.
Old Apr 19, 2007 | 01:20 PM
new2me's Avatar
ORIGINAL: Cruz734
The factory recomends for it to be changed at 100,000 miles, so its not a bad idea to do it early just to be safe. Why would you think you need a T-belt?
sdboarder84,
Where did you buy the car from they might have the records. Or you can try Audi America.
