timing light
Old Dec 31, 2005 | 09:08 PM
germancarmaniac's Avatar
Default timing light
do i need a timing light to do my timing belt on my 99.5 1.8t. I got the step by step on audiworld.com. Any input would be awesome since im doing it tomorrow. thanks
Old Dec 31, 2005 | 09:23 PM
_Adrian_'s Avatar
Default RE: timing light
nope ..
but i recomend doing the folowing:
1. disconnect battery
2. turn engine manually untill you hit TDC (Top Dead Center)
3. mark all the timing marks with chalk (both on gears and block)
4. remove belt & replace
5. adjust tensioner
6 double check timing marks
if any mistakes made you may damage valves and pistons.
i recomend turning engine over by hand a couple of times to make sure everything is ok.
I left out a couple of steps like removing the covers.
i meant this to be as a guide for proper alignmet of timing marks so you dont end up smackin the valves.
good luck and becarefull double and tripple check your work !!!!!
better safe than sorry, right ??
Old Dec 31, 2005 | 09:29 PM
agreed!! The type-up on the site was really good and showed all of the steps. Plus ive got all the tools in the world( I work at a shop), and zedex is swinging by to give a hand. Starting at 8:00am tomorrow morning. 2audi guys+tools+A4+beer-the hangover from tonight=FUN
Old Dec 31, 2005 | 09:31 PM
tip5's Avatar
Good LUCK! Let us know what happens and take some pics.
Old Dec 31, 2005 | 10:32 PM
ota dota! sounds good
malhar
May 4, 2012 10:22 AM
Audiguruforyou
Sep 20, 2011 01:31 AM
katiebear00
Mar 2, 2010 07:29 PM
littleflavio
Dec 3, 2007 04:54 AM
