Tire size question
Subscribe
Sep 18, 2007 | 05:26 PM
Is anyone running 235/45/17 tires on 17 inch wheels?
I currently have 225/45/17 and would like to know if I can go slightly wider on the same wheels.
Anyone running this size?
Thanks!
Reply
Sep 19, 2007 | 11:50 AM
RE: Tire size question
Bump.....
Wow, no one with 235 or larger on 17's?
I guess I'll be the first then. Or is everyone else running 225? Maybe the 235's are slightly to big? They do have the size available, soI am sure it will fit the wheel.
Reply
Sep 19, 2007 | 11:53 AM
I had 235's on my a4, I took it down to 225, cuz I like the look of it
Reply
Sep 19, 2007 | 11:56 AM
I have 225's on my 16s. You'll be fine on 235's.That is a common width on 18's and 19's..
Reply
Sep 19, 2007 | 11:58 AM
225's on my 17's.. i could run 235's without a problem
Reply
Sep 19, 2007 | 03:52 PM
ya 235 are fine you can run 245 with no prob wither
Reply
Sep 19, 2007 | 04:18 PM
Changing you section width 225 to 235 will change the tire diameter therefore effecting your speedo. If my calculations are correct when the speedo says 75 you would be doing 76.
Reply
Sep 20, 2007 | 09:23 AM
My '03 Sport has 235/45/17's on it.
Mike
Reply
Sep 21, 2007 | 01:03 PM
my 04 sport has 235's stock.
Reply
Sep 21, 2007 | 01:19 PM
Quote:
ORIGINAL: tfische12
Retard!!!!
Reply
Subscribe
