Tire Wear
Old Jun 27, 2007 | 08:02 AM
mgp2001's Avatar
Default Tire Wear
Found out the other day that I have extreme wear on the inside of my front two tires that are only 1.5 years old. I have a Quattro. The guy at Discount Tire tells me it's typical of 4 wheel drive Audis due to the differential arrangement forcing tire rotation during a turn. I don't think so. These cars have All Wheel Drive, meaning that power is transfered to those tires needing it most (i.e. with traction). I think the wear is due to alignment issues as there is no wear on my rear tires. Any thoughts appreciated.
Thanks.
~ MGP
Old Jun 27, 2007 | 08:32 AM
Black_97 A4's Avatar
Default RE: Tire Wear
could be alignment or check tire pressure..
Old Jun 27, 2007 | 09:03 AM
bam_bam's Avatar
Usually, excessive wear on the inside of a tire means you have negative Camber, or maybe even a bit too much toe-out.
Alignment can take care of that.
Old Jun 27, 2007 | 01:21 PM
tfische12's Avatar
I had the same problem on my passenger front tire. It was cause by worn out control arms. It could be your alignment also or both. I would check control arms first.
Old Jun 27, 2007 | 01:27 PM
acetrebo's Avatar
Is your car lowered?
Old Jun 27, 2007 | 07:29 PM
Boostfed13's Avatar
I had the same problem I had my car aligned and the toe was way out of spec no issues so far after the alignment.
Old Jun 27, 2007 | 10:14 PM
OrangeA4's Avatar
i get my tires rotated every year. they are switched for the seasons each year then after a year the front tires go on back and back tires go on front. (dont flame me, it was my dad who does it all the time). 2000 1.8T Q B5
Old Jun 28, 2007 | 01:57 PM
ironman's Avatar
first i would look at TRE and next alignment
Old Jun 28, 2007 | 02:05 PM
techbod's Avatar
ORIGINAL: mgp2001
Thanks.
~ MGP
defiantly a problem and not common to the AWD at all ( inner ware = toe out problem ) warranty I think
adioman6000
Nov 9, 2010 10:57 PM
fireman9585
May 19, 2010 08:25 AM
fireman9585
Jun 9, 2008 06:24 PM
fireman9585
Jul 18, 2007 01:51 PM
seaurchin99
May 26, 2005 11:39 PM
