tranny fluid
Old Dec 11, 2005 | 06:24 PM
lamchop's Avatar
Default RE: tranny fluid
do you guys remember were the fill hole is on the tranny, i was under the car last night changeing the gas filter( pain in the butt) and i am not sure were i would fill it at. thanks
Old Dec 12, 2005 | 04:44 AM
pitobaby76's Avatar
its the large plug on the rear end of the tranny pan. it is 17mm hex. when u drop the pan ull see exactly how u will fill it.
Old Dec 12, 2005 | 03:18 PM
lamchop's Avatar
so the fill is on the rear of the tranny pan? that doesn't sound right but i will find out this friday when i get rest of the fluid.
Old Dec 12, 2005 | 03:52 PM
jukeit's Avatar
ORIGINAL: lamchop
Need to do my fuel filter. Why was it a pain in the butt? Any tips?
Old Dec 12, 2005 | 09:29 PM
lamchop's Avatar
there is a write up on it which helped alot but even with the tank strap (2) off the tank didn't move much, i had to use a pry bar to get it low enough so i can get to the screw, when i finally was able to get the key in with a pair of channellocks to turn it, the nut in the back was spinning with it do to rust, i ended up cutting the bracket with a saw saw blade to get the filter out, after that it was easy.
Old Dec 13, 2005 | 01:50 AM
John_E's Avatar
ORIGINAL: lamchop
Mine is (1996 2.8Q 01V automatic)
Old Dec 13, 2005 | 04:59 PM
lamchop's Avatar
the tranny might be different on the 2.8 compare to the 1.8t. i will look again when i am under there
FtCA4
Dec 18, 2007 04:38 PM
audijunky_1
Nov 19, 2007 08:04 PM
nugger
Jun 11, 2007 12:54 AM
toyolla86
Sep 25, 2006 04:46 AM
