Transimission problem?
Old Jul 27, 2007 | 11:47 PM
zx2004's Avatar
Default Transimission problem?
I recently purchased a used 99 Audi a4 (with AWD). I noticed when I drive up a relatively steep hill; the car will not go past around 20mph. When I step on the gas, engine RPM goes up but the car does not accelerate.
What’s even stranger, is that after I got up the hill and drive on regular road the car “stuck” in this mode and will not accelerate past 20 mph with engine RPM going past 3000+. It only returns to normal after I stop to car completely and start over. Although I didn’t drive the car long enough (less then a minute) in the “speed limited mode” to find out if it return to normal on its own.
Is this behavior a “feature” of this particular Audi model, or is there something wrong with the car?
If transmission is indeed damaged, the car still runs perfectly, when I drive on regular road, accelerate and decelerate normally with out any problem.
Any suggestions?
Thanks in advance
Old Jul 30, 2007 | 09:19 AM
SLVR99A4's Avatar
Default RE: Transimission problem?
99 A4 Quattro Tip....my transmission has alsobeen acting up. I do know with the tiptronic transmissionit will adjust to grade when driving up a hill. This means when driving up a hill it usually stays in that gear longer before shifting. Mine has always done this but has never limited to just 20 mph. When driving normally my transmission has a tendency to run really quick through the gears, I even had it reset recently which solved the problem for a while but now has gone back to normal. Under hard acceleration it runs great, shifting normally. Also under heavy load from 2-3k rpm my tranny slips like the torque converter isn't adjusted or set right during highway traveling. Sorry I do not have an answer for you, I am still learning myself on how critical these machines operate and how sensitive they are according to their parameters. Maybe our Tip modules need to be replaced..???
Christopher Nemitz
Mar 12, 2012 09:02 PM
hfd#12
Sep 22, 2011 05:16 PM
jimc137
Mar 9, 2011 06:48 PM
audi_tt_4u
Dec 26, 2010 02:20 PM
spyrosg7
Apr 4, 2010 07:48 PM
