transmission A4 quattro 1997
Old Apr 28, 2005 | 02:54 AM
KPzan's Avatar
Default transmission A4 quattro 1997
My 1997 A4 quattro, auto, with 112,000 miles is vibrating in higher gears when the car is warmed up. When you take the power off and coast the vibration goes away. Seems the transmission is on the way out? Do you know if it is better to replace with a rebuilt trans or repair this one? LP
Old Apr 28, 2005 | 03:05 AM
BFlan2001's Avatar
Default RE: transmission A4 quattro 1997
replace it if it's going bad, don't try to repair it...
Old Apr 28, 2005 | 03:14 AM
KPzan's Avatar
Are the rebuilts any good, better to go new, or one from a wreck yard? How long can I drive the car like it is. LP
Old Apr 28, 2005 | 03:24 AM
BFlan2001's Avatar
i don't know how serious your damage is, so i don't know how long it'll last....do you have the 1.8t or the 2.8? if you have the 1.8t, you can get the 2.8 tranny, which is stronger...a rebuilt is probably your best bet.
Old Apr 28, 2005 | 04:53 AM
KPzan's Avatar
I have the 2.8. The vibration isn't too bad. A mechanic dropped the pan and said there were no metal shavings, but the oil is burnt (sigh of heat?). Do you know of any tranny shops in So Cal for rebuilts or is it best to go through a dealer?
Old Apr 28, 2005 | 05:07 AM
BFlan2001's Avatar
if you've got the money you can take it to a dealer, but expect to pay about twice as much...i'm in norcal, so i can't help you with shops...
Old Apr 28, 2005 | 01:12 PM
Mr_You's Avatar
Burnt oil? Maybe it should have been changed more regularly?
Old Apr 28, 2005 | 01:18 PM
hb972.8q's Avatar
A new transmission is about 5,000
A rebuilt one is about 2,500 rebuilt trany
a used one is about 1,000 used
cost about 600 or so to install at a non-dealership
would recommend getting a new clutch at the same time, cause it would be free to install
damn didn't read too good you have an auto....i think the prices will be about the same but just skip getting the clutch
Dalakian
Nov 6, 2012 02:58 PM
littlebigmon
Apr 18, 2011 01:41 AM
MartinCieslak1
Sep 24, 2010 11:21 PM
Pitts.PAAUDI
Mar 21, 2009 09:35 AM
AWD4g63
May 19, 2008 09:51 PM
