TRANSMISSION DIPSTICK
Old Feb 3, 2005 | 09:44 PM
Brich's Avatar
Default TRANSMISSION DIPSTICK
ON A 97 QUANTRA A4, WHERE IS THE TRANNY DIPSTICK. I CAN'T FIND IT, IS THERE ONE?
Old Feb 3, 2005 | 09:58 PM
Jestnomen's Avatar
6th Gear
Default RE: TRANSMISSION DIPSTICK
no such thing. Audi says the tranny fluid is a "lifetime fill".
Old Feb 4, 2005 | 12:47 AM
flyboy's Avatar
Not even on Auto?
Old Feb 4, 2005 | 01:59 AM
david9999's Avatar
Even on a "Quantra".
You may be a noob, but first at least make the effort to learn your car's name.
The Auto transmission is a"lifetime fill".
What means that you don't change it until your transmission breaks.
Of course, your transmission will break sooner if you don't change the transmission fluid.
The transmission fluid has to be checked from underneath the car, with the car perfectly level, and the transmission fluid warmed up slightly. Generally I leave this to a local garage that specializes in Audis.
While you are at it, you may want to change a few quarts of transmission fluid, the fluids from the center differential and rear differential. Bleed the brakes. get a turkey baster and swap out the power steering fluid. Use new Pentosin 11 fluid only. Top up the battery with distilled water, drain your radiator and re-fill with new VW pink antifreeze and distilled water.
Your car will thank you.
wdills
May 12, 2015 08:30 PM
Don_Korcari
May 14, 2010 12:52 PM
ambig1.8t
Dec 26, 2008 01:13 AM
SouthernAudi
Oct 11, 2007 07:13 AM
1staudi
Dec 2, 2003 04:27 PM
