Transmission fluid
Can someone advise me of what should I use for a tranny fluid. I have a 2001 A4 1.8T with tiptronic. I am thinking of using synthetic. Any thoughts and ideas? Please give me the pros and cons before I make the switch. Can also advise me on the difficulty of changing it? I can't seem to find the dipstick for the tranny, does anyone know where it is?
[sm=smiley9.gif]Sorry about the link... I was mistaken re: which fluid you were replacing, so... I searched around for you and here's what I found out.
There is no way to do this yourself from what I learned. The fluid has to be at a specific temp and the vehicle needs to be VAGed during the process. Some of the info was confusing, but i got the impression that it isn't easy.
It was clear that it is expensive to have it done, but the 40K interval helps spread the cost out over time. [sm=smiley20.gif]
There was a consensus that Redline and Royal Purple are the fluids of choice, though.
Sorry I couldn't help anymore.
no it isnt easy you have to get the tranny up to a certain temp thats why tyou need the vag to check the temp then you have to get under the car which requiers lifting it but not with a jack it has to be level then you can drain the fluid using the drain plug bug nthe only way to fill it is through another hole that you take a plug out of which is kind of a tube that opens at the height wich the fluid should be at said temp ....now to get the right amout you have to get a hose and pump it in that tube at first just eyeball it and make sure you get enough fluid for the tranny to opperate then when the vag reads the correct temp you keep pumping fluid in untill it starts to drible out of the hole you pumping it in...easy huh? goto the dealler for this
OK - just take it to a dealer - it will cost you anywhere from 125 - 200 dollars to have new fluid put in. Its too much if a PITA to do it yourself. And ATF for tiptronic is not normal fluid - Royal Purple does not make anything that is recommended, nor does Redline. Use Pentosin brand, or OEM.
If you don't have a VAG - don't even bother attempting it yourself. Getting the car to accurate temp is actually very important. other than the temp deal, its easy to do it yourself with a fluid pump. Just pump it until you feel fluid about 1cm below the top level of the inner fill plug lip. But the car needs to be at temp before you do this. Otherwise you will an inaccurate amount of fluid in there.
And for the americans - ESSO = Exxon... heh heh
