Transmission fluid and speaker size
I just bought a CPO 02 A4 with 1.8T and Tip. The car has 60K and I'd like to change the transmisson fluid. What should I get, and how much do I need to buy. I've always trusted RedLine Fluids in the past, is this ok to use and what weight should I buy?
I'm also about to replace all of the factory speakers with Boston Acoustics. I have the Bose Symphany II system now, what size speakers does that come with?
Thanks guys!
Thanks guys!
Hey If I were you I would invest in a Bently Manual. There is more to chaning your tranny fluid than you would think. You have to have diagnostic tools (ross tech's Vag-com) to view the transmission temperature. It also requires special tools to get the transmission fluid up into the pan.
I actually didn't know about any of that stuff when I change mine on my 97 A4. I just found the tranny cooler and removed the lines, Then I put in the amount I drained out of it.
