tuneup needed?
Old Aug 10, 2005 | 03:34 PM
travsearle's Avatar
Default tuneup needed?
I've got a 2001 A4, 1.8T Quattro that just hit 43k miles. I bought it back in April. In the last couple weeks or so it feels like it's started being a little sluggish, acceleration seems to be lagging a bit in the middle/higher gears. The car is in good shape, I got it cert. pre-owned and over all I think it runs well. I'm just wondering if a bit of a tune-up is in order, maybe doing the plugs and so forth? How difficult is this and is it worth having a mechanic do it? Any other things to consider now that I'm up over 40k?
Thanks.
Old Aug 10, 2005 | 04:05 PM
clconversion's Avatar
Default RE: tuneup needed?
plugs are easy enough just take off the plastic engine cover and there are 4 coil pack over each cylinder that you need to remove to get at the plugs could be a small vacuum leak also not allowing it to boost completly do you have a boost gauge ?
Old Aug 10, 2005 | 07:39 PM
CRAZYHAWK's Avatar
At 40K mi you should also change the air filter. You can get these plugs and filter from
www.rockauto.com
Emilgevor
May 12, 2011 06:37 PM
MarkR540
May 12, 2010 07:29 AM
etf42
Jun 18, 2009 11:45 AM
audi_98_a4
Jul 31, 2007 07:28 PM
spartakent
Apr 30, 2007 01:08 PM
