Turbo bolts
Old Nov 24, 2006 | 08:23 PM
dozentrio's Avatar
Default Turbo bolts
This is a problem that has been plaguing my car for ages. The previous owner tried all sorts of things and nothing worked. Now it's my problem. I thought I'd post and see if anyone has any bright ideas.
My car has a Kinetic MS exhaust manifold and k04 turbo. The Kinetic mani is a lot beefier than the stock one, so longer bolts are required. The bolts keep coming loose. And believe me, they've been tightened plenty. Hmm... what else. The transmission grinds and chatters in 1st gear, so that might be causing some vibration. (soon to be fixed) It's a B5 1.8t manual by the way. High-flow catalytic converter. Borla exhaust. Also, last time i fixed it, the bolts were stretched visibly. It was actually rather amazing they didn't break. It's a real pain because each time they come lose, the turbo gasket gets destroyed and my car sounds like ****, and I don't want people thinking I don't take care of my Audi.
Old Nov 24, 2006 | 10:23 PM
JohnnyBravoA4's Avatar
Default RE: Turbo bolts
did you use lock washers, or even any loctight?
Old Nov 24, 2006 | 10:24 PM
for the tranny try flushing and changing the fluid
Old Nov 25, 2006 | 05:35 AM
raimond's Avatar
The problem is probably with bolts. In exchaust manifold special bolts should be used because of hight temperatures. Normal bolts just get stretched under hight temperature. I had similar problem when changed bolts on catalytic converter and after week or so they just were getting loose (became longer).
Old Nov 25, 2006 | 01:17 PM
good point, weild the bitch together..
Old Nov 25, 2006 | 08:00 PM
dozentrio's Avatar
I'm using bolts specced for the heat, i've tried a locking plate, not sure if the former owner tried locktite... i'll give it a shot. Hopefully it doesn't melt or do anything funky from the high temp. Yes, maybe if all else fails i'll weld the sucker, haha
Old Nov 25, 2006 | 08:50 PM
dafrazi's Avatar
There is a high temp Locktite formula.
The chattering in 1st gear may be caused by a lightwieght flywheel. Did the prevous owner have one installed. They are notorious for chattering.
Old Nov 25, 2006 | 09:52 PM
only the Aluninum ones chatter.. from what I was told.. and anything lighter then 15lbs
Old Nov 26, 2006 | 01:08 AM
BaconBait's Avatar
For the turbo bolts, get some ARP bolts or tack weld the thing.
Jackball42
Aug 28, 2008 11:31 PM
Jackball42
Aug 28, 2008 11:29 PM
pschmid
Apr 2, 2008 05:26 PM
pschmid
Mar 25, 2008 06:33 PM
lehighwiz
Jun 1, 2007 09:52 AM
