removing turbo from manifold...WTF are those bolts?
Old May 30, 2007 | 06:52 PM
lehighwiz's Avatar
Default removing turbo from manifold...WTF are those bolts?
I am currently trying to separate the turbo from the manifold. There are three bolts there that go down from the top into the turbo. They appear to be a 6 point backwards torx looking head. Do I need a special tool to get them off?
Thanks,
MB
Old May 30, 2007 | 07:18 PM
theTTkid's Avatar
Default RE: removing turbo from manifold...WTF are those bolts?
if its a torx looking head... im going to have to go out on a limb and say a torx should do the trick... maybe a pic would help too
Old May 30, 2007 | 08:51 PM
lehighwiz's Avatar
ORIGINAL: theTTkid
i found the right socket from a buddy of mine. Its called an E-Torx...i still managed to round one of them off though so now i have to deal with that problem.
MB
lehighwiz's Avatar
ORIGINAL: theTTkid
the sockets look like this:
http://www.amazon.com/FEMALE-E-TORX-.../dp/B000I45Y8Q
Old May 30, 2007 | 10:08 PM
theTTkid's Avatar
Mmm thats crazy, good luck!!!
Old May 30, 2007 | 10:15 PM
cincyTT's Avatar
I'm make believe
thats gotta suck. Mineare regular 17mm bolts.
Old May 30, 2007 | 10:33 PM
theTTkid's Avatar
just out of curiosity though, why are you taking out your turbo??
Old May 30, 2007 | 10:50 PM
225tt's Avatar
Replace the Flux Capasitor? Or is it the Kuniter Valve? I had to do mine last week, hahaha...
Old May 31, 2007 | 09:01 PM
lehighwiz's Avatar
ORIGINAL: theTTkid
i'm not, i'm actually removing the head to replace bent valves (timing belt) and its easier to remove the head with the manifold attached and remove it later...i actually got those bolts off now and i'm sending the head out to an engine shop to be reworked.
Old Jun 1, 2007 | 09:52 AM
theTTkid's Avatar
oh ok, well then... good luck
410ThirtyValve
Nov 25, 2013 09:48 AM
prsalmon
May 31, 2011 06:29 PM
Cmoney
Sep 6, 2010 05:14 PM
pschmid
Apr 2, 2008 05:26 PM
pschmid
Mar 25, 2008 06:33 PM
