Turbo Boost
Old Jul 20, 2004 | 12:55 AM
audiboy1618's Avatar
Default Turbo Boost
Ok, i obviously i know chips turn up the boost, but how do you turn up the boost without the chip, my mechcanic said theres a way, but i dont know how.Anyone know?
Old Jul 20, 2004 | 01:19 AM
Doose's Avatar
Default RE: Turbo Boost
Adjusting the wastegate controls boost.
Old Jul 20, 2004 | 01:45 AM
wheres the wastegate at?, can this be done yourself?
Old Jul 20, 2004 | 02:14 AM
Doose's Avatar
It's usually looks like a threaded rod connected to large vale on the exhaust side of the turbo. You can move the vavle from open to closed by adjusting the nuts on that threaded rod. Basically, when you open the waste gate it allows the exhaust gasses to flow past the turbine not through it, therefore less boost. If you close the waste gate all of the exhaust gasses are forced through the turbine and then you get more boost. It's not real easy to get to in our cars. It's on the bottom side of the stock turbo if I'm not mistaken.
Old Jul 20, 2004 | 02:26 AM
Ok, well the reason im asking this is because I told my audi dealer i wanted for power, I asked about the chip, he said he would void my warrenty but he did said he would allow the boost being turned up, as labor is expensive, how long would this take him to do?
Old Jul 20, 2004 | 02:38 AM
Doose's Avatar
Well, techically the chips do void the warranty. If you've got the coin, you could buy another ECU and chip it. Then just swap ECU's when you have to take the car to the dealer. As for the waste gate adjustment, it akes about two minutes to adjust it, it's getting there that's the problem. I think you have to take quite a bit off just to get to it. Another thing is, I don't know how the stock turbo is set from the factory. If it's set fully closed then there's nothing more you can get out of it. If it's partially opened then we're talkin. Let me do a little research on this and see if I can find out how it's set from the factory.
Old Jul 20, 2004 | 02:44 AM
Thanks for the help doose, could you maybe get back to me tonight?
Old Jul 20, 2004 | 02:47 AM
Well, i was just thinking, ive seen chips that turn the stock k03 boost up in the teens, so it cant be fully closed,right?
Old Jul 20, 2004 | 02:48 AM
Doose's Avatar
Yep, I'm on it. If I can't find anything tonight, I'll for sure be back on tomorrow mid morning. Be back in a few...
Old Jul 20, 2004 | 03:01 AM
ok, thanks doose
