Turbo and chip help
Old Jan 22, 2006 | 02:38 PM
ryanmcell's Avatar
Default Turbo and chip help
Ok I am about to upgrade my 01 A4 1.8t quattro. Heres what I want to do but I am not 100% sure on it
--k04-015
--APR w/93 oct
Will this chip work directly with this turbo? Cuz i keep reading about people upgrading their chips when they get the k04 to a k04 chip? Am i confused or just reading stuff wrong. Let me know!!
Also with this setup which DV should I go with, and injectors?
Old Jan 22, 2006 | 02:43 PM
aRIf's Avatar
Default RE: Turbo and chip help
I think you should go with Giac with you want K04 upgrade
Old Jan 22, 2006 | 02:44 PM
onepoint8tee's Avatar
I think only giac or stock programing works with k04.. Your gunna need some extra things other than the chip and turbo, like an exhaust, injectors?, fpr and i dont know what else? I think??? I should know these things by now.
Old Jan 22, 2006 | 02:49 PM
ryanmcell's Avatar
ORIGINAL: onepoint8tee
oh i know, these were the only 2 things i wasnt sure about then.
i just am not sure what size injectors to get.... i was thinking 380cc but i dunno. u guys tell me lol
Old Jan 22, 2006 | 02:50 PM
aRIf's Avatar
as far as I know, you have 2 options
Normal Giag program or PC-16/J31
If you go Giac I think 93 you do not need any other parts
If you go PC-16 then you will need 310cc inj, fpr, fmic because this software little extreme.
Old Jan 22, 2006 | 02:51 PM
ryanmcell's Avatar
where do i check out the pc-16 for spec & buying info?
Old Jan 22, 2006 | 03:07 PM
KelticSlob's Avatar
I don't think PC-16 file is available for anything newer than 99.5 models.
Old Jan 22, 2006 | 03:14 PM
ryanmcell's Avatar
alright so then if im going to check out a giac chip i gotta find out if my ecu is ch or m first right?
Old Jan 22, 2006 | 03:37 PM
FASTER's Avatar
Tech Slut
you can code an APR chip to run a k04. i thought about it with my 93oct apr program, butthen just got giac.
Old Jan 22, 2006 | 04:00 PM
ryanmcell's Avatar
ok fastera4thanurs which giac chip (could you link me) should i run?
