turbo install
Old Jan 17, 2007 | 02:34 AM
keko2004's Avatar
Default turbo install
so i just purchased a brand new k03 for 200 bucks. i droipped my car off to my mechanic this morning. tomorow i want to call him and make sure things are going correct. is there anything i should tell him. i cant rememeber where i read it, but someone said to oil something on the turbo before install. i could be mistaken. also, my mechanic found the line from the turbo to the air filter is busted, where can i get this part other then the dealer?
Old Jan 17, 2007 | 02:51 AM
akielb's Avatar
Default RE: turbo install
How much is he charging you for the install?
There is no "line" that goes from the intake to the turbo.
maybe he's talking about the turbo inlet pipe or somthing like that. Thats all I see when looking at my Bentely diagrams
Have him figure out the proper name of the part or take pictures and post on here
Old Jan 17, 2007 | 03:29 AM
SMoLiK's Avatar
Sounds like the intake tubing from the turbo to the filter is busted... I would ask to take a look at it for myself...
If the mechanic knows what he is doing he will oil the turbo properly, he should also unplug the coil pack and crank the engine over for ten seconds, let it sit for five, crank for ten, let sit for five and crank for another ten to make sure the turbo has oil before starting the car up...
SMo'
Old Jan 17, 2007 | 04:26 AM
BadLuckAudi's Avatar
they best way by far to oil the turbo is leave the intake tube off then you start it and take a wooden stick and hold the blades from moving, have someone else start the car and let it idle while still holding the blades for a min.... this will ensure the turbo is oiled properly
Old Jan 17, 2007 | 04:35 AM
onepoint8tee's Avatar
ORIGINAL: BadLuckAudi
haha that sounds so wrong but it would definatelywork
Old Jan 17, 2007 | 05:06 AM
AudiCross's Avatar
but thats a defanit do at own risk. if you mess up and get wood in ur brand new turbo, ur not gonna be a happy camper
Old Jan 17, 2007 | 05:27 AM
dude that how every good mechanic does it... wellthat actually does work on lots of turbo motors.... Remember I worked at a dodge dealer and thats how all the techs were trained to do it, and thats also how all the old smart guys that work on cat's at my dads work do all the turbos and they are doing them almost everyday..... its much safer then just pulling the coils cuz even the not running motor will turn the turbo and can casue damage, holding the blade is the only 100% safe way to do it
STiPsi
May 20, 2009 03:00 PM
SouRce4
Mar 18, 2008 06:53 PM
skeezo3000
Jan 31, 2008 11:30 PM
FantasiA4
Jun 24, 2005 08:51 PM
audiboy1618
Sep 7, 2004 01:49 AM
