turbo lag?
Old Feb 1, 2005 | 02:38 PM
brrman's Avatar
Default RE: turbo lag?
2 second delay does not sound normal. The turbo lag on a stock a4 is noticable, but hardly 2 seconds. 1/2 a second maybe.
Old Feb 1, 2005 | 06:48 PM
David_K's Avatar
ORIGINAL: audihere
i know what ur doin. ur trying to launch it at a higher rpm arent u. bc when u do this its not like a honda or anyother reg 5spd. it seems to fall right on its face then all of a sudden its taken off. u have to ease into a launch unless u have an aftermarket clutch. u will screw ur stock one up if u r trying to do this. i learned this when i first got mine. 1 thing i hate about audis
i can launch just fine. it falling on its face for you cuz your dumping the clutch instead of letting it slip. the once the stock clutch heats from the slip it grabs hard
Old Feb 1, 2005 | 07:11 PM
D4rw1n's Avatar
If you already have the timing belt kit, how much does it usually cost to get it intalled? Do they have to pull the engine for a timing belt kit install?
Old Feb 1, 2005 | 07:13 PM
David_K's Avatar
not pull the engine but you have to strip down the front pretty good. exspect to spend part of friday all of saturday and part of sunday to do it your first time. thats how long it took me
Old Feb 1, 2005 | 08:17 PM
audihere's Avatar
Banned
david thats what im sayin hes prob doin is what i used to do until i figured it out...lol but ya i see what ur sayin
Old Feb 1, 2005 | 08:24 PM
Jestnomen's Avatar
6th Gear
A typical independant labor cost for a timing belt change is $400-700. Here is a pic when I did mine, so you get an idea of how much has to be removed:
Old Feb 1, 2005 | 08:28 PM
audihere's Avatar
Banned
holy **** did u actually do anything else with that down time lik eput some cams in that bad boy. thats some serious time and effort for just some belts. i got qouted 350 for mine i know thats where ill be takin mine whne needed
  #18
D4rw1n's Avatar
Where did you find the walk through to install the kit?
Timing Belt Kit = http://www.germanautoparts.com/Audi/A4/Engine/223/2
Old Feb 1, 2005 | 08:36 PM
  #19
Jestnomen's Avatar
6th Gear
http://www.audiworld.com/tech/eng31.shtml
http://www.audiworld.com/tech/eng35.shtml
No, I didn't do anything else to my car while I was in there. Just changed the snub mount.
03a418tnate
Aug 10, 2010 08:07 PM
mr V8
18
Jun 23, 2006 03:21 AM
DickM
12
Mar 21, 2006 05:15 AM
