turbo making weird noise
Old Jul 23, 2007 | 06:51 PM
Rdssk8boardr69's Avatar
Default turbo making weird noise
i have a 2000 audi a4 1.8t auto
with an apr chip
it boost properly everything for the most part runs great
but when its boosting hard it makes a weird almost whistle. not like an air leak but like kinda the sound a whistle makes like the metal ball rolling around inside. has anyone ever had this problem before? i had teh shop check for air leaks and there are none. its just a really loud sound that i am almost positive is different from that of normal turbo boost!
HELP!
Old Jul 23, 2007 | 07:00 PM
onepoint8tee's Avatar
Default RE: turbo making weird noise
Thats the sound you get when a turbo the size of your fist is pushing 15+psi.
The ball rolling around sound is sort of odd. Does this only happen after a cold start and get better as the car warms up? Stay off heavy boost until the engine has had enough time to warm up/cirulate oil through the system.
Old Jul 23, 2007 | 07:59 PM
cletusdafetus's Avatar
it might be your waste gate mine made the same noise and was broken rattling around
dunno?
Old Jul 23, 2007 | 08:23 PM
ORIGINAL: cletusdafetus
dunno?
The rattling wastgate arm sound is usually only audible after a small rev while idling. Ive heard a couple A4's with that problem before though. Was that not the case for you?
Old Jul 23, 2007 | 08:35 PM
when it would build boost it rattles like crazy for a couple seconds then when the throtle closed same thing but only made about 2psi most the time
term437
Aug 2, 2014 01:36 PM
Dacantra
Nov 20, 2013 02:30 PM
chitown2.7T
Mar 26, 2009 09:31 PM
6605stang
Mar 7, 2009 03:11 AM
SILVER_B5S4
May 8, 2007 12:42 PM
