turbo question
Old May 2, 2007 | 04:22 AM
  #21
Belligerenceā„¢'s Avatar
Default RE: turbo question
to run a GT turbo you'll need injectors, exhaust, and a 5 bar FPR at the very least. probably a FMIC as well. oh and programming too, obviously.
Old May 2, 2007 | 05:12 PM
  #22
mikejda's Avatar
know does someone have the programming for the GT ( GIAC OR APR), or do you have to tune it yourself? I was just wondering that versus buying the KO4 with GIAC or APR tuning.
Old May 2, 2007 | 10:20 PM
  #23
Audiquette's Avatar
Cool Thread....does anybody know where i can find out more about the BT turbo? i tried googling it but no real help. thanks guys
Old May 2, 2007 | 10:27 PM
  #24
NuYorka103185's Avatar
ORIGINAL: eurokid
all you need really to run a k04 is a chip, dv and an n75 valve upgrade
Dont upgrade your N75 for the K04, you'll spike allover. When I had my N75J in my car sounded like a superduty at 1800rpm LOUD!!!! Plus it would cause my DV to make weirn noises. Stock N75 back in and it is much better.
Old May 2, 2007 | 11:50 PM
  #25
pyropenguin's Avatar
Some turbo options for the A4-
Chipped k03 (needs diverter valve)
K04 on base software (needs diverter valve)
K04 PC-16/J31/hammer file (needs diverter valve, fmic, intake, exhaust, fpr, injectors, and i think that's it)
BT's:
GTRS Eliminator w/ tuning (needs diverter valve, intake, fmic, exhaust, fpr, injectors, and i think that's it)
2871 eliminator w/ tuning (needs diverter valve, intake, fmic, exhaust, fpr, injectors, and i think that's it)
Full GT28RS w/ tuning (needs diverter valve, intake, fmic, exhaust, fpr, injectors, Exhaust manifold, and i think that's it)
Full GT2871RS w/ tuning (needs diverter valve, intake, fmic, exhaust, fpr, injectors, Exhaust manifold, and i think that's it)
GT3071 w/ tuning (needs diverter valve, fmic, intake, exhaust, fpr, injectors, Exhaust manifold, and i think that's it)
GT35 w/ tuning (needs diverter valve, fmic, intake, exhaust, fpr, injectors, Exhaust manifold, and i think that's it)
Then theres the T03/T04 setups, I'm not sure where they fit in. Those turbo setups are ranked from least power, to hte most power. I know mike2point0 on audizine is running 500+ whp from a GT35.
Edit-
Audiquette, BT = Big Turbo. Basically anything bigger than a K04. The GT30's and above are sometimes called B.A.T's (Big *** Turbo), too.
Old May 3, 2007 | 02:17 AM
  #26
mikejda's Avatar
pyropenguin thats great info thanks.
But i still have 1 question, With the KO4 set-up you can but a ecu by GIAC or APR, etc. With the GT series is there also a GIAC,APR, etc. ecu or do you have to tune it yourself?
thanks
Old May 3, 2007 | 02:22 AM
  #27
Audiquette's Avatar
Thanks pyropenguin....great info
-Very Humble Noob
Old May 3, 2007 | 03:25 AM
  #28
Jovian's Avatar
The basic K04 also needs a 5 bar FPR
ORIGINAL: pyropenguin
BT's:
Edit-
Old May 3, 2007 | 03:32 AM
  #29
96audia4's Avatar
Technically, you dont need anything for a K04, but in order to get any extra power out of it you need programming and some other stuff (depending on how aggressive the programming is).
Old May 3, 2007 | 04:53 AM
  #30
ORIGINAL: mikejda
thanks
APR has tuning for the K03 and I think the GTRS eliminator (in their Stage III kit).
GIAC has a file for the K03, K04 basic, and K04 PC-16/J31/Hammer.
For the bigger turbos, there are companies like Unitronics and CTapp, or you can get it custom tuned.
Just realized you have a B6 Audiquette, most of the stuff I've said should still apply, but there may be a little bit different.
