Turbo Question????
did diode mod and the car runs great. Much better at 14 psi. Cranked it up to 18 psi and it runs great at that too. Thank you guys/gals. Now I just need abigger turbo..........
I forgot to tell you that it is a zener diode, not a zennerand there is two part numbers for it 1) 1N4731A 2) NTE568A . Also when hooking up the diode on a 01' A4 Quattro the stripe part of the diode needs to be toward the blue wire. If it is the other way it throws a check engine light.
