Turbo spools sometimes
Old Jun 6, 2007 | 02:45 PM
Quattro_1.8t's Avatar
Default Turbo spools sometimes
Only mod I have is a test pipe. My turbo will build boost most of the time but sometimes you can tell theres no boost building althought you can hear the turbo slightly. Im thinking its the wastegate pulley being stuck or possibly a boost leak somewhere? Any ideas? its a 99.5 a4 1.8tq. It has been doing this for a while even before I got the test pipe.
Old Jun 6, 2007 | 02:47 PM
Jeff's Avatar
Zombie Defense Force
Default RE: Turbo spools sometimes
ya check the wg and check for leaks. sounds like a stuck wg because if it was a boost leak it would happen all the time
Old Jun 6, 2007 | 03:07 PM
cincyTT's Avatar
I'm make believe
a boost gauge would be nice in cases like this.
Old Jun 6, 2007 | 04:39 PM
Lazer Viking's Avatar
the wastegate dosent have a pully
Old Jun 6, 2007 | 08:31 PM
Bondga's Avatar
perhaps your going in and out of limp mode?
Old Jun 8, 2007 | 01:21 AM
Sometimes the car jerks as it builds boost. Normally you just hear the turbo spooling but no boost at all.
Old Jun 8, 2007 | 01:43 AM
onepoint8tee's Avatar
Get a boost gauge. Its not only nice, its a necessity when diagnosing boost issues if you dont have access to vag com to log boost levels.
Old Jun 9, 2007 | 02:57 AM
Im planning on it since I'm chipping the Ecu within a month. Gotta get the timing belt and water pump done first
Old Jun 9, 2007 | 02:58 AM
Jeff's Avatar
and a dv with the chip
Old Jun 14, 2007 | 01:08 PM
I have a bailey motorsport DV
5Speedwtneed
Nov 2, 2010 10:44 AM
Noobinator
Oct 12, 2007 03:03 PM
mr V8
18
Jun 23, 2006 03:21 AM
