turn signal
Old Nov 12, 2004 | 12:04 AM
A4Aram's Avatar
Default turn signal
Hey guys, i got a problem with my turn signals like the whole system. Theres nothing wrong with any of my bulbs they still work i check and nothing wrong with my fuse i cheeck n tried that out, but everytime i put my signal on it does like half a clik without the turn signal lights going on and stops. What should i do and whats the problem? thanks
Old Nov 12, 2004 | 12:10 AM
Jestnomen's Avatar
6th Gear
Default RE: turn signal
probably the relay. That would be located behind the hazard button in the dash. Push the hazard button in and see what happens.
Old Nov 12, 2004 | 08:29 AM
david9999's Avatar
Agree with Jestnomen. Sounds like the relay.
Old Nov 12, 2004 | 12:07 PM
A4hud_'s Avatar
I also agree with Jest and david, it does sound like the relay. haha A4aram is my twin brother, we share the car!
Old Nov 12, 2004 | 12:59 PM
A4Aram's Avatar
i push in the hazard and it works the turn siganlas work it only doesnt work when i use the actual signal both right and left.
Old Dec 2, 2004 | 02:05 AM
pcstalboerger's Avatar
I had the exact same thing go wrong with my 01 A6 2.7T a month ago. I checked fuses and also determined it was my relay. I called the audi shop and bought the relay for $30 and took apart the dash portion near the switch to replace the entire hazard switch/relay. Not a piece of cake - but once you do it's not that bad.
gquin1
Jun 5, 2008 12:22 AM
pa4ul
Jan 21, 2008 03:20 PM
mrdb85
Aug 22, 2007 08:20 PM
scotia4444
Apr 23, 2007 10:41 AM
paliracer
Feb 21, 2005 03:15 PM
