turn signal
Old Aug 20, 2007 | 10:40 PM
mrdb85's Avatar
Default turn signal
i have a 1997 1.8t. when i start my car for about the first 15 minutes i get this loud vibrating sound coming from the radio/ac cluster. i can feel it on the hazard switch, but i am not having any problems with my signals. it even radiates through the radio and causes static. could this be a faulty hazard switch? i read some of the other posts and it seems as if this a common problem.
also i had my ignition switch replaced and now my signal doesnt retract after i turn the wheel, i took off the steering wheel and couldnt seem to figure out why. dont know if maybe there should be some kind of o-ring around the shaft that retracts the signal, or if that whole signal cluster needs to be replaced. Any suggestions?
Old Aug 20, 2007 | 11:00 PM
auditech79's Avatar
Default RE: turn signal
The hazard switch usually is a common replacment item, but when you get buzzing its commonly caused by the turn signal switch shorting out the hazard switch. So you're gonna need a need turn signal switch along with a hazard relay.
Old Aug 21, 2007 | 10:09 PM
mrdb85's Avatar
i know the hazard needs to be pryed out with a screw driver, where is the turn signal switch located and how do i replace that??
Old Aug 22, 2007 | 04:16 PM
auditech79's Avatar
The turn signal switch is the lever you use when turning on your blinkers. You have to remove the air bag, remove the steering wheel and spiral clock spring, then un-flange the turn signal switch from the steering shaft and slide it out.
Old Aug 22, 2007 | 07:49 PM
mrdb85's Avatar
i got a problem, the screw behind the steering wheel holding in the air bag is stripped. WTF, anybody have any suggestions??????
Old Aug 22, 2007 | 08:20 PM
auditech79's Avatar
Its a T30 Torx, Try to get a T30 torx socket in there and bang it on with a hammer then turn it out.
gquin1
Jun 5, 2008 12:22 AM
pa4ul
Jan 21, 2008 03:20 PM
scotia4444
Apr 23, 2007 10:41 AM
paliracer
Feb 21, 2005 03:15 PM
A4Aram
Dec 2, 2004 02:05 AM
