TWO CODES NEED HELP
Old Jun 21, 2006 | 11:19 PM
JohnnyBravoA4's Avatar
Default TWO CODES NEED HELP
got two codes dont know what they mean wanted to know if anyone could look them up or give me a link so i could do it myself.. would be nice if anyone could shed some light on my problems
422, 301 got it done at autozone but the guy didnt have the book...
99 1.8t Aeb Ko4, custom test pipe, custom cat back, giac non -c 16 file, evo dv, AFPR set to 5 bar, N75 race valve
thanks for any help you guys can give
Old Jun 21, 2006 | 11:28 PM
onepoint8tee's Avatar
Default RE: TWO CODES NEED HELP
ORIGINAL: JohnnyBravoA4
If you mean code P0422: Main Catalyst Efficiency Below Threshold Bank 1
and if you mean P0301: Cylinder 1 Misfire Detected
The #'s you gave, or he gave you arent vag or sae codes.. But since they would be using an sae obd tool, im just guessing thats what they are, because sae codes start with a "P0" and i just added the #'s you gave to that and looked it up in the bentley.
sounds to me like you may have a bad 02 sensor, and maybe a bad coil pack or plug or connection.
Old Jun 21, 2006 | 11:33 PM
yea its an obd tool sorry i didnt put the letters infront of my codes forgot them becasue he didnt give them to me..
well i dont have a cat, so I would asume my primary o2 sensor is no good because or maybe my secondary, i know my primary is messed up because the threads are fed and it thows a code everyone once in a while but never these two..
been running no cat for a while now and never got a code like that, been about 8000 miles with no cat..
would bad plugs cause a missfire.. why whould it misfire..
Old Jun 21, 2006 | 11:41 PM
yeah a bad plug can cause a missfire. Do you know when theyve been replaced? Pull em out and check em. Replace them if you dont know when theyve been replaced obviously. P0301 could also be your engine/rpm speed sensor.
[IMG]local://upfiles/10408/C20BA387EFE04A6D819DD2765B515D15.jpg[/IMG]
Old Jun 21, 2006 | 11:46 PM
could that be why my car dose not seam to want to pull hard in uper RPM's, it seams like the car hits a wall the boost stays high 16psi to red line but it just dose not pull
yea im almost positive i need plugs i had a lean condition for a while then i got the AFPR and now i have a rich condition and i have no clue when the last time the plugs where changes, only had the car for 8500 miles did the belt and all the other stuff about 200 miles after I bought it.. that would be 2 days i had to drive it back from NY
Old Jun 21, 2006 | 11:51 PM
Well most of us with the K03 notice the lack of pull in the higher rpms compared to the lower rpms. The k04 should help with that, but not completely. If you had a bag plug or coil pack im sure you would notice it as much in the lower rpms as the higher. Since you dont know when the plugs have been replaced DEFFINATELY change them. Also, you mentioned you didnt have the right k04 programing which may have something to do with your power complaint. Change your plugs and let us know what happens. Try to get the code cleard for the missfire/engine speed sensor and see if it comes back after new plugs are in. If the code comes back, switch the coil pack on cyl #1 to cyl #2, clear the code again, and see if it comes back as a cyl #2 missfire, then youll know its the coil pack. If all else fails, its probably your engine/rpm speed sensor.
Also a bad 02 sensor will take away some performance and gas mileage.
Old Jun 21, 2006 | 11:56 PM
thanks alot for the help and the info, im going to order new plugs and fix that dam crapy o2 sensor tomarrow and have the codes cleared, im not a big fan of this non pc 16 program my buddy with the dalbach program and the ko3s in his 97 seams to pull harder then mine dose in higher rpm's and he has less bost at red line 12psi to my 16.. I need to get a fmic and the injectors and im sure most of my problems will go away with the pc-16 file
Old Jun 22, 2006 | 12:02 AM
i wouldnt order the plugs personaly. If you can get back to autozone, just get some BKR6E's and gap them between .028 and .030. Like $2 each. They are copper, and will give you best performance, but will need changing every 10k miles or so. I think the new plugs and 02 sensor should restore some performance for you. If the 02 sensor hasnt been replaced and you have anywhere close to 100k miles, it would be wise to do it even if its not bad. They get lazy over time. Wait a couple weeks and get scanned again and see what happens. Get the pc-16 file asap too!!! Your welcome for the help, anytime i can use my bentley is a good time for me.
Old Jun 22, 2006 | 12:06 AM
I was going to get the NGK's 868 from ECS the ones that run a little cooler, the ones they recomend for the apr stage 3 set up.. you think they would be a wast of money.. if so ill just get the ones you just told me to get, i do alot of driving and im not nice to the car at all. well I keep her clean and fix everything I break asap but evert 10k would probibly be like 3 times a year i guess thats not so bad..
Old Jun 22, 2006 | 12:10 AM
You dont want to get too cool of a plug. Deffinately go with NGK BKR6E. Your setup isnt even close to APR stage 3. I think Arif runs BKR7E which is one step cooler than the bkr6e, and well, you know about his setup...
