TWO CODES NEED HELP
got two codes dont know what they mean wanted to know if anyone could look them up or give me a link so i could do it myself.. would be nice if anyone could shed some light on my problems
422, 301 got it done at autozone but the guy didnt have the book...
99 1.8t Aeb Ko4, custom test pipe, custom cat back, giac non -c 16 file, evo dv, AFPR set to 5 bar, N75 race valve
thanks for any help you guys can give
ORIGINAL: JohnnyBravoA4
and if you mean P0301: Cylinder 1 Misfire Detected
The #'s you gave, or he gave you arent vag or sae codes.. But since they would be using an sae obd tool, im just guessing thats what they are, because sae codes start with a "P0" and i just added the #'s you gave to that and looked it up in the bentley.
sounds to me like you may have a bad 02 sensor, and maybe a bad coil pack or plug or connection.
yea its an obd tool sorry i didnt put the letters infront of my codes forgot them becasue he didnt give them to me..
well i dont have a cat, so I would asume my primary o2 sensor is no good because or maybe my secondary, i know my primary is messed up because the threads are fed and it thows a code everyone once in a while but never these two..
been running no cat for a while now and never got a code like that, been about 8000 miles with no cat..
would bad plugs cause a missfire.. why whould it misfire..
yeah a bad plug can cause a missfire. Do you know when theyve been replaced? Pull em out and check em. Replace them if you dont know when theyve been replaced obviously. P0301 could also be your engine/rpm speed sensor.
[IMG]local://upfiles/10408/C20BA387EFE04A6D819DD2765B515D15.jpg[/IMG]
could that be why my car dose not seam to want to pull hard in uper RPM's, it seams like the car hits a wall the boost stays high 16psi to red line but it just dose not pull
yea im almost positive i need plugs i had a lean condition for a while then i got the AFPR and now i have a rich condition and i have no clue when the last time the plugs where changes, only had the car for 8500 miles did the belt and all the other stuff about 200 miles after I bought it.. that would be 2 days i had to drive it back from NY
Also a bad 02 sensor will take away some performance and gas mileage.
thanks alot for the help and the info, im going to order new plugs and fix that dam crapy o2 sensor tomarrow and have the codes cleared, im not a big fan of this non pc 16 program my buddy with the dalbach program and the ko3s in his 97 seams to pull harder then mine dose in higher rpm's and he has less bost at red line 12psi to my 16.. I need to get a fmic and the injectors and im sure most of my problems will go away with the pc-16 file
I was going to get the NGK's 868 from ECS the ones that run a little cooler, the ones they recomend for the apr stage 3 set up.. you think they would be a wast of money.. if so ill just get the ones you just told me to get, i do alot of driving and im not nice to the car at all. well I keep her clean and fix everything I break asap but evert 10k would probibly be like 3 times a year i guess thats not so bad..
