Two Errors-CEL - what do they mean?
Old Dec 13, 2006 | 10:05 PM
zuzuk212's Avatar
Default Two Errors-CEL - what do they mean?
Hello,
It's a 2000 a4 quatro with the following prob.[:@]
The CEL prompted me to have autozone check the codes for me. They gave me:
P1411 - SAI system incorrect downstream flow detected
P1423 - EGI functioanlity test failed
I searched, found and understand that the 1411 error is the secondary air pump ... where is it located?
Any ideas on the 1423?
Any tips would be great ... also, when I do fix this will the CEL turn off or does it need to be cleared. Autozone said that they are not allowed to clear codes any more.
Thanks,
Ken
Old Dec 13, 2006 | 10:34 PM
zuzuk212's Avatar
Default RE: Two Errors-CEL - what do they mean?
Oops ... sorry I just found another, better post explaining:
https://www.audiforums.com/m_197201/tm.htm
But, still reply for the location of the air pump.
Thanks,
Ken
Old Dec 14, 2006 | 03:00 AM
zuzuk212's Avatar
Ok, the solonoid Ohm'd ok.
Where do I find the fuse for the pump ... I did not find one on the pannel ... also, is this pump located in front of the engine, lower pass. side?
When I do fix this will the CEL turn off or does it need to be cleared?
Thanks,
Ken
Old Dec 14, 2006 | 03:04 AM
tractioncontrol's Avatar
Your doing great diagnosing this for yourself. Yes it will needed cleared, it should be stored in pending codes if not still a current code and light on.
Old Dec 14, 2006 | 04:37 AM
sean1.8t's Avatar
you'll run better without your secondary air system anyways... just food for thought
Old Dec 14, 2006 | 04:42 AM
zuzuk212's Avatar
How do you get by emission testing then?
Old Dec 15, 2006 | 04:46 PM
zuzuk212's Avatar
Bump.
Any input?
Thanks,
Old Dec 16, 2006 | 02:51 AM
sean1.8t's Avatar
you either hook the combi valve and all back up to proper functionality(not super hard at all), or you grease the emissions tester 10 bones
snatchman
Jul 17, 2013 10:07 PM
adika
Jun 20, 2013 02:56 AM
4RINGSROD
Sep 23, 2008 12:22 AM
gbove
May 22, 2008 01:04 PM
wkayl
Dec 20, 2006 02:35 AM
