uh oh (intake nipple) w/ pics
Old Dec 26, 2007 | 08:41 PM
tdn's Avatar
tdn
Default uh oh (intake nipple) w/ pics
so i was taking the hose off the manifold intake nipple device thing, and it snapped.. very easily. it almost looks like it's threaded in.. is this right? anyone know the part number or correct name?
it snapped almost flush, so it'll be a pain to get it out of there if it's threaded.. but i'll just be happy to know that if it's threaded it'll be an easy fix. if its not.. ****!!!
Old Dec 26, 2007 | 08:44 PM
onepoint8tee's Avatar
Default RE: uh oh (intake nipple)
Huh? In your case, a picture would be worth a million words....
Old Dec 26, 2007 | 08:46 PM
cincyTT's Avatar
I'm make believe
Is it the brake booster line? Ibelieve thats threaded, and the other lines are molded in.
Old Dec 26, 2007 | 08:47 PM
tdn's Avatar
tdn
definitely, i'll post some up tomorrow. this just happened 2-3 hours ago, it was pretty dark so i decided to worry about it tomorrow.
Old Dec 26, 2007 | 08:48 PM
sanjay.debian's Avatar
I was working with the vacuum hose just today. It didn't look to me like the nipple is threaded. But am not 100% sure.
Old Dec 26, 2007 | 08:53 PM
tdn's Avatar
tdn
it's the fuel pressure regulator. well.. sanjay and cincy say it's not threaded.. lame! hmm.. i wonder how i should go about fixing this.
Old Dec 26, 2007 | 09:03 PM
cincyTT's Avatar
I'm make believe
If you broke the fpr, just go buy another one. Thats not part of the manifold though.
Old Dec 26, 2007 | 09:10 PM
tdn's Avatar
tdn
the fpr has a vacuum hose to the manifold.. am i wrong? i'm going off a bad picture off of a haynes manual so I could be completely off. anyway, the vacuum hose nipple i snapped is on the manifold side, i just might have the wrong name. i'll have to check in the morning.. don't mean to sound lazy, car is parked a few blocks away and i'm about to go to sleep.. it's been a long day.
Old Dec 26, 2007 | 09:12 PM
The fpr wouldnt just snap off though... Well, shouldnt. The weakest part is burried in the fuel rail and the top/sturdy part is clipped into the neck of the fuel rail. Does it look like this?
If you snapped the intake manifold nipple then that is bad. Youd have to get a new nipple welded on. I cant imagine how the **** you broke it though. Its not exactly fragile.
Old Dec 26, 2007 | 09:24 PM
cincyTT's Avatar
I'm make believe
A used intake man should only be $100-150 tops. For a temp fix you could just block the hole (if need be, getto it with jb weld) and just T into another manifold vac source. Not a big deal. I would rather swap manifolds instead of trying to fix this one.
