Uh oh, its not starting!
Old Sep 17, 2007 | 03:16 PM
doubleDee's Avatar
Default Uh oh, its not starting!
Well it does then it cuts off. It was flat bedded off to the garage, non dealer as i had a very bad experience with them. The problem is that the diagnostic equpment fails to find the issue.
Has anyone else had this problem. Its a A4 3.0 2003 cab
Old Sep 17, 2007 | 03:20 PM
techbod's Avatar
Default RE: Uh oh, its not starting!
what diagnostic equipment are they using?
Old Sep 17, 2007 | 03:22 PM
onepoint8tee's Avatar
Could be a few things. If it doesnt acknowledge diagnostic equipment, then it could be a bad ecu. Hard to say.
Old Sep 17, 2007 | 03:26 PM
sdboarder84's Avatar
do you have an aftermarket stereo? if so who ever installed it they have hard wired it instead of using a harness could have cut the K wire, which would allow to never be able to communicate with your car again.
Old Sep 17, 2007 | 03:32 PM
doubleDee's Avatar
Not sure what diognostic equipment they are using. No aftermarket sterio. I cant see it being the ECU as it starts up, fuel pump relay or Maf sensor is a possibility.
Old Sep 17, 2007 | 03:43 PM
techbod's Avatar
its an 03 car and you need CAN bus diagnostics the early type wont work on that car, VAG HEX-CAN 704 software free download
http://www.ross-tech.com/vag-com/download/
Old Sep 17, 2007 | 03:47 PM
doubleDee's Avatar
How should I go about asking the guys if they have the right equipment, I dont want to seem to be rubbing there faces in it so to speak.
Old Sep 17, 2007 | 03:50 PM
acetrebo's Avatar
Guess you should flatbed it to the dealer then, if they cant figure out the problem.
Old Sep 17, 2007 | 03:51 PM
doubleDee's Avatar
like I said I had a bad experience with the dealer, so much so I would never trust my car there again.
Old Sep 17, 2007 | 03:59 PM
techbod's Avatar
a mechanic wont be annoyed if you ask him/her what the diagnostic tool they are using just say your considering buying the VAG kit your self and they will fall over them selves to tell you
