UHHH..
I said in my "boost gauge" post about how my low beam light doesnt work after my gauge install. Im guessing it happend when i was testing for a groud while the lights were on... The high beam works, and the fuses are not blown. Is there anyway I could have fried anything electrical???? Im scared now. I havent taken the low beam bulb out cuz i dont know how.. Its the HID unit i think.. I dont know about that stuff.. What do you think??
ORIGINAL: clconversion
damm right sounds like you got a short somewhere retrace you steps and check the wiring
Do you think if i vag it, that will give me an answer?
sorry to hear that... u sure that u checked the right fuse... so.... unplug one of your low beam wiring from the headlight and turn it on and test if is there a power coming ? if yes, then your bulbs are gone. if not, then .... I dont wanna think about it....
ORIGINAL: aRIf
i like to but i'm at work in downtown now. if you are close to me let check it out now (i have not take my lunch yet) and I will be in downtown area until 10 pm [:@]
or
jus go to advence auto parts on bethel rd. and buy a volt tester
you can check and see if there is a power in a cable or not. no need voltmeter.
or
I don't thionk the vag will give you the answer what did you wire you boost gauge light into ?
ORIGINAL: aRIf
or
or
